Author Topic: Breakdown  (Read 22063 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Breakdown
« Reply #15 on: 29 October 2015, 16:31:19 »
I should have added that, this occurred on start up after event free driving and parking, the steering was just solid, however, if I gave it about 3000 rpm, I ocsnly got a slight bit of power steering back. This would indicate to me that it is unlikely to be electrical failure, as I don't think the relay would be affected by revs. :-\
The fluid tends to turn to shit as the pump breaks down inside.
The amount of assistance that the pump gives is dependent on the car speed (probably taken off the abs sensors)
If the relay is oppsed, my money is that it will shut a valve in the system somewhere so you get no assistance :-\
Exactly, so unlikely to give any assistance even at high revs.
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #16 on: 29 October 2015, 16:31:54 »
Fingers crossed that its relay, but I'll message my mate who used to have TD Elite he broke a number of years ago, he took all useful bits off it, and promptly shoved them all in storage. I've had a bloody shed load few bits off him in the past. Will pop him a message  :)
Thank you James. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Breakdown
« Reply #17 on: 29 October 2015, 16:34:17 »
Unless the 3000 revs gave a voltage spike which kicked the relay in for a few seconds until it finally burnt out  :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Breakdown
« Reply #18 on: 29 October 2015, 16:36:39 »
If needed, there are a few pumps on eBay ranging from 20 quid (used) upto 80 quid (new)
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #19 on: 29 October 2015, 16:39:12 »
Not many for the TD though. :(
Re: Breakdown
« Reply #20 on: 29 October 2015, 16:43:26 »
IIRC if the servotronic relay or fuse fails it just defaults to either "min" or "max" assistance .. not "no" assistance.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Breakdown
« Reply #21 on: 29 October 2015, 16:44:24 »
Don't forget the E34 BMW 5 series had the same engine  ;)
I'd still swap the relay first though
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #22 on: 29 October 2015, 16:50:11 »
Ah OK, thanks Aaron, I was trying to avoid grovelling under the glove box, but on reflection, probably easier than changing the pump.
Is there an easy way to test the Rl in the bench, otherwise I hope RobG has one, although I know he usually keeps FL bits. ::) :y
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #23 on: 29 October 2015, 16:51:48 »
Yes, I did know that, and I see the pumps advertised for both together, so another option. :y
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #24 on: 29 October 2015, 17:19:14 »
Does anyone know if its possible to check the relay on the bench with a simple test meter and a 12v battery?
Re: Breakdown
« Reply #25 on: 29 October 2015, 17:20:35 »
Not sure the TD has servotronic at all, does it? Thought that was the preserve of the V6, but may be wrong.
In any case, no electrical failure mode will give you no assistance. Worst case it'll get a bit heavier but not enough to prompt a trip home on a recovery truck.
Given that the behaviour was RPM- related, my money is on a failure of the pump. :y
Re: Breakdown
« Reply #26 on: 29 October 2015, 17:24:32 »
Presumably the belt is intact :-\
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #27 on: 29 October 2015, 17:26:12 »
Thanks Kevin, confirms my thinking also. It doesn't help that the handbooks are generic and list a 30A fuse for the steering etc., but as you say, may not apply to mine. None of the pics I've seen of replacement TD pumps appear to have electrical connections. :y
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #28 on: 29 October 2015, 17:26:53 »
Affirm, first thing I checked. :y
Re: Breakdown
« Reply #29 on: 29 October 2015, 17:29:40 »
I figured it would be but we all have our Homer Simpson moments ;)
