Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Breakdown  (Read 23354 times)
0 Members and 3 Guests are viewing this topic.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Breakdown
« Reply #45 on: 30 October 2015, 15:20:14 »
Rebuilt pump ordered for approximately a third of the car's value at £120. As I will flush the system before fitting the new pump I came across this http://www.dvatp.com/bmw/power_steering_flush, which is interesting. I have previously changed the fluid as I had to remove a damage pipe, but I had not considered regular flushes. :y
omega2018
    • MercCL500 Omega2.6ManElit
Re: Breakdown
« Reply #46 on: 30 October 2015, 17:29:54 »
did you get any warning signs?
i think my pump is on the way out - fluid won't stay clean, apparently it is a pattern pump. two or three times now i have had very stiff steering on startup, even with some revs.  problem went within a minute and seemed to improve after a few fluid flushes.
i hadn't appreciated pump failure is a show stopper, has assumed i could still steer, just it would be a lot stiffer.  another thing to worry about being stranded with.
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #47 on: 30 October 2015, 17:38:08 »
None at all, parked up, fine, 1 hour later started up, steering almost solid!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Breakdown
« Reply #48 on: 31 October 2015, 22:46:23 »
Indeed, and up until Kevins post, I was feeling very stupid, as I had never thought the pump was electrically assisted in some way. (It may still be). I'm hoping Seth might tell me, I think he still has his TD. :y
Got a spare pump here, though can't see any electrickery on it, Chris ???
Although our TD's now in semi-retirement, you're welcome to a lend. For elimination purposes, if you wish ;)
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #49 on: 01 November 2015, 09:51:54 »
New one on order Byron, thanks anyway. :y :y :y :y :y :y
Shackeng
  • Ramsbury
Re: Breakdown
« Reply #50 on: 12 November 2015, 18:17:38 »
For interest, the 'rebuilt' pump i bought from Steering Specialists e-Bay for £120, I was advised by the supplier these are new OE pumps bought as surplus stock from GM. :y
omega2018
Re: Breakdown
« Reply #51 on: 23 December 2015, 12:35:01 »
just wondering if the new pump fixed this in the end.  if so is the oof conclusion that a pump failure will always/sometimes result in total immobilisation of the car?
useful to know - i had always assumed before it would just be like switching the engine off while moving - still steering and braking but both much stiffer. might be worth carrying a spare pump.
Re: Breakdown
« Reply #52 on: 23 December 2015, 12:36:35 »
TD pumps are different to the rest of the range iirc...
Cornelius123
  • us
    • BMW
    • Casesam
Re: Breakdown
« Reply #53 on: 24 December 2015, 02:18:04 »
There are a few pumps online. ::)
Re: Breakdown
« Reply #54 on: 24 December 2015, 11:47:09 »
Steering gets heavy and brakes require more press.
Its dependent on how able you are, I have driven a towed Omega on three occasions with no engine running fro 100 miles or so each time and its quite doable.
Re: Breakdown
« Reply #55 on: 24 December 2015, 11:48:54 »
but you'd prefer not to  ;)
  • Auckland
    • Mazda MPV
Re: Breakdown
« Reply #56 on: 24 December 2015, 15:03:40 »
I had a 15 mile tow behind an AA van on a rigid bar.
OK on the open road but I thought the steering shaft was going to snap at T junctions and tight corners.
Re: Breakdown
« Reply #57 on: 24 December 2015, 18:37:38 »
.... I had a 15 mile tow behind an AA van on a rigid bar.
and it makes it evem more difficult when you can't see up the road because of the van
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Breakdown
« Reply #58 on: 24 December 2015, 19:01:47 »
I had one of those I think they should be banned.steering is very difficult and I wonder what damage it does to the towed car.
Re: Breakdown
« Reply #59 on: 24 December 2015, 20:25:56 »
Done that... Fortunately as a result of clutch failure.  I still had brakes and steering, which the AA chap hadn't allowed for braking at roundabouts :D
Trying to brake gently when the towing (ie 4ft in front) vehicle brakes hard (whilst compensating for the car on the tow bar) for roundabouts :D
I would count to five when he braked and then brake gently... Redefined ripping the arse out of summat ::) poor sod didn't know what to do ;D
Pages: 1 2 3 [4] 5  All   Go Up
