Author Topic: ABS ECU help or advice please  (Read 9273 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« on: 30 October 2015, 11:27:11 »
Ok Yesterday (after 3months of sitting) took out the mig for a drive and first few miles didnt notice it then out of nowhere notice the speedo has a mind of its own when driving, rev still working fine. Initial thought was instrument panel needs a nudge, after a few whacks still nothing. Removed & cleaned connections, still have same problem so dug up another intrument panel to see if current one is faulty, but nope still doing same.
Reason why im now having to point at the abs ecu is i have noticed the odd heavy steering, but then again read up if abs ecu fault then the light comes on, in my case it doesnt stay on.
Any help what it could be, or anything else i could try will be greatly appreciated  :y
Re: ABS ECU help or advice please
« Reply #1 on: 30 October 2015, 11:56:36 »
Speedo is probably donald... not the same as an ABS ecu issue unless the light is on ;)
« Reply #2 on: 30 October 2015, 11:58:26 »
But he tried a different instrument panel?
« Reply #3 on: 30 October 2015, 12:01:11 »
Misread that bit :-[
The contacts behind might benefit from some contact cleaner, both on the cluster and the dash end...
« Reply #4 on: 30 October 2015, 12:14:04 »
The steering is also periodically going heavy, so that points to the ABS system, as that's the common, since it generates the speed signal that both the instrument panel and the servotronic use.
Failure of the ABS ECU is a common problem. It might be on its' way out.
Might be worth getting a tech 2 on it to see if there are any faults stored in the ABS ECU. Odd that the warning light doesn't come on, though.
Stallion
  • Romford
« Reply #5 on: 30 October 2015, 12:42:10 »
Thanks for the promot response guys  :y! Just a thought read somewhere about abs sensors on the rear? could they have gone dirty/sticky/corroded/faulty as car was sitting for a while. Just want to be sure before putting up a wanted ad.
As for tech2 Kev, no ones local to me.
« Reply #6 on: 30 October 2015, 13:01:05 »
Zirk might be able to help with the diagnostics  :y
Stallion
  • Romford
« Reply #7 on: 31 October 2015, 17:00:59 »
Do the omegas have speed sensors on all four wheels or only the front 2! :y
« Reply #8 on: 31 October 2015, 17:47:14 »
Ecu averages it from all four...
Stallion
  • Romford
« Reply #9 on: 31 October 2015, 18:10:55 »
Thanks  :y, been to the local garage who has tech 2, no faults stored apart from the usual 0420/0430. Back to square 1  :(
Stallion
  • Romford
« Reply #10 on: 07 November 2015, 01:20:45 »
As some might have noticed put up a wanted ad for abs ecu unit and got some response (phew).
Now the question is do i choose the unit that matches my engine/gearbox or choose the unit with the same part number?  ???
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #11 on: 07 November 2015, 02:53:54 »
and then bleed the system with Tech2 to open the valves :-\ :-\ I think :'(
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 07 November 2015, 09:43:31 »
Why is the Tech2 necessary? When I changed my ECU/valveblock we bled the brakes normally.
Stallion
  • Romford
« Reply #13 on: 07 November 2015, 13:11:39 »
Is the abs ecu not a simple plug & play?
  • Chatham, Kent
« Reply #14 on: 07 November 2015, 13:36:45 »
I replaced the entire assembly as the fault codes related to the valve block, so had to bleed the brakes. If you just change the ECU then bleeding won't be necessary. Considering how bad the access is for a theoretically simple job, I would not attempt to change the ECU in place. But then we all have a different opinion of difficulty and what we will put up with.
