Author Topic: New key  (Read 4200 times)
EMD
  • Noofhampton
    • 95t
New key
« on: 31 October 2015, 13:01:37 »
Ive only got 1 key and thats all that came with the car , but its well worn out . Where will i get a replacement as the key needs cut with the new fob . Are there any different blanc fobs that work  :-\
Omegatitis
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: New key
« Reply #1 on: 31 October 2015, 13:50:42 »
This is my "Get me in the car key" And that is all it will do,, i had it cut for £5 From a Timpsons hut outside tesco..
Re: New key
« Reply #2 on: 31 October 2015, 13:55:46 »
That's what I told my daughter to get for her Fiat because a new key is dealer only at around £200 and her car is a 52 plate Siecento worth bugger all. Obviously she didn't and when she locked her one & only key in the boot .........  :-X
It took the recovery over an hour & a half to get in the first time she did it .............. I took less than a minute when she next did it  ;D ;D
Steve B
  • Leicestershire
Re: New key
« Reply #3 on: 31 October 2015, 14:07:29 »
It was just a "what if i lock my only key in the boot thought when i was in tesco carpark moment" Andy.So i just offered the asian chap a fiver to run me a blank off and he did....
You could super glue a transponder to it and it would be a spare key to run the car after a Tec2 meet... It would then just set the alarm off only  :y
Or you could put it on the ring with the 3 button one,Then it will work perfect without a transponder  ;D ;D ;D
EMD
  • Noofhampton
    • 95t
Re: New key
« Reply #4 on: 31 October 2015, 17:19:16 »
Where you get that key from ?  :)
Omegatitis
Re: New key
« Reply #5 on: 31 October 2015, 17:34:18 »
My guess is Timpsons .......  ::) ::)
Steve B
  • Leicestershire
Re: New key
« Reply #6 on: 31 October 2015, 18:11:29 »
;D ;D ;D
Re: New key
« Reply #7 on: 02 November 2015, 17:43:39 »
Blanks with a transponder are available for under a tenner delivered. Car obviously needs programming to transponder.
Or horseshoe blank with transponder is same price, and fob part about £25+VAT (trade) from dealer. Obviously, still needs programming.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: New key
« Reply #8 on: 02 November 2015, 18:51:30 »
Presumably the fob needs programming to the car via tech 2 as well as the transponder ?
Re: New key
« Reply #9 on: 02 November 2015, 20:28:23 »
Technically the car needs programming to the fob and transponder. But yes, both fob and transponder :y
EMD
  • Noofhampton
    • 95t
Re: New key
« Reply #10 on: 03 November 2015, 12:50:31 »
I bought a bran new fob but when i tried pressing the buttons it was virtually impossible to press as the buttons/casing were so hard  :(
Omegatitis
Diamond Black Geezer
    • & a silly coupe coming...
Re: New key
« Reply #11 on: 03 November 2015, 13:40:02 »
Pattern ones are, they're really bad. I ended up reverting to a tatty, but 'ok' one I found in a scrappy.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: New key
« Reply #12 on: 03 November 2015, 18:10:24 »
I took the transponder out of my one good key and taped it to the lock barrel in the appropriate place. Then any key cut like the good key would open the door and start the engine. It left the car not immobilised, but who pinches Omegas?
Re: New key
« Reply #13 on: 03 November 2015, 19:52:48 »
Sometimes, spending 99p is false economy.
