One for EMD (welding)
Started by Webby the Bear, 02 November 2015, 18:18:14
Webby the Bear
RIP Paul Lovejoy
Quote from: Webby the Bear on 02 November 2015, 18:39:22
thing with welding is you tend to blast it  with a grinder anyway so as long as the metal sticks two pieces then grind it and its job done  ;D
If that's the case, you need a lot more practice! You should should never grind a weld, but it's often necessary on car body work to hide the join on external panels. Welding under the car is best left alone.
Webby the Bear
Lol I never said I was an expert. I still have lots to learn. On the welding and the auto repair front  :y
RIP Paul Lovejoy
