Author Topic: Fitting 314mm calipers  (Read 2520 times)
Sir Sideways
  • Sideways in Staffordshire
    • PFL 3.0 Auto Elite Estate
« on: 04 November 2015, 13:14:53 »
Has anyone fitted a set of 314mm calipers? are they a straight bolt on fit or would I need adapters? if so where could I get some?
Many Thanks
Jim
Re: Fitting 314mm calipers
« Reply #1 on: 04 November 2015, 15:40:58 »
Give us a clue... ::)
What calipers?
Where from?
Front or rear?
Sir Sideways
« Reply #2 on: 04 November 2015, 18:31:37 »
Front calipers from signum
« Reply #3 on: 04 November 2015, 18:57:52 »
Assuming the bolt spacing is the same, 85mm iirc, then they will probably bolt on... but Vec C discs are about 13mm shallower than Omega ones, 45.2 mm vs 58.3 mm which gives all sorts of issues such as wheel offset and hub offset... you could find the caliper fit fine, but the discs won't, or that all fits well but the wheels then foul the caliper when you spin them... might also struggle to fit 16" wheels...
If you can get the parts cheaply enough, then try it and report back :y
Sir Sideways
« Reply #4 on: 04 November 2015, 19:06:37 »
I have calipers, pads + disks sat in garage waiting. Its just getting round to having a look. Thought id just ask the question if it had been done before.
Thanks for the info harris, it may come in useful
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 04 November 2015, 19:30:41 »
Something in the back of my puny brain is telling me the Discs and Callipers will be fine.  The Calliper Carrier will need modifying as the bolt holes do not line up.  I also think you need to trim a small section off the splash-guard.
« Reply #6 on: 04 November 2015, 20:04:57 »
Possibly thinking Monaro VXR rears, as all the above apply...
Sir Sideways
« Reply #7 on: 05 November 2015, 00:47:55 »
ok thanks, ill probably have a look at fitting them next year as I'm busy every weekend now till xmas.
