Author Topic: wherer is low coolant warning on an R reg GLS petorl manual?  (Read 12241 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: wherer is low coolant warning on an R reg GLS petorl manual?
« Reply #15 on: 08 November 2015, 19:23:55 »
How should one prepare the egg? Fried?
We're talking poached eggs here, Webby, no fat involved. Doubt you've ever heard of them.  ;D
 ;D far cough
On a serious note I personally wouldn't do it. Let's say it acts the same as rad weld then it's going to clog the system. For proof of this the header tank in my mums car has a layer of shite in it after I put k seal in. Would never use it again and instead, repair the leak.  :y
RIP Paul Lovejoy
« Reply #16 on: 08 November 2015, 19:26:16 »
I had a small leak in my car, about half a litre a week. Couldn't afford to lose the car until half term so I just topped it up every night. No dramas.  :)
I had the cleanest coolant in town.  :y
Webby the Bear
  • Northampton
« Reply #17 on: 08 November 2015, 19:29:09 »
Exactly what I do with my current small leak. Top it up once a month.  Always got fresh coolant. JD  :y
RIP Paul Lovejoy
Vicar
  • staffs border
    • 2.0 CD
« Reply #18 on: 08 November 2015, 19:50:26 »
for starters, put an uncooked egg in the header tank bring up to temp as you suggested, whilst your waiting the HBV kicks in and you now have half cooked egg heading it's way to the heater matrix rad, what doesn't get stuck in there will end up probably cooked on its way to your front rads.
I wouldn't even think about putting Radwel in my Omega let alone a raw egg.
Likewise !!
Thats the idea, it goes round the whole system and when it finds a hole to get out of it will get pushed into it by the pressure if the water and stick to it the heat of the water then cooks it hard and seals the leak. I have had good success with this and no smells of any sort.
I wouldn't use Radweld either, eggs are cheaper than a cheap thing.  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #19 on: 08 November 2015, 20:02:30 »
You do talk 'dangle berries' sometimes vicar.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #20 on: 08 November 2015, 20:06:34 »
Likewise !!
I know  how it works, and 40 years ago I would have probably agreed with you, but with modern high temp closed coolent systems its just asking for trouble.
Vicar
  • staffs border
    • 2.0 CD
« Reply #21 on: 08 November 2015, 20:07:41 »
Ahh no worries eh, just a wee suggestion to help a fellow enthusiast.
What works for some etc, this trick has never failed me.   :y
No-one has still said why it isn't a good move or said what damage it'll cause.
« Reply #22 on: 08 November 2015, 20:19:39 »
No one would tell you why it wasn't a good idea to stick your dick in a mincer. If you don't know, you don't know.  ;D
zirk
  • Epping Forest
« Reply #23 on: 08 November 2015, 20:22:53 »
You're be telling me to put Golden Syrup in the Oil next to cure a failed Oil Cooler
« Reply #24 on: 08 November 2015, 20:24:06 »
Now you're just being facetious.  ;D
Vicar
  • staffs border
    • 2.0 CD
« Reply #25 on: 08 November 2015, 20:41:52 »
This one I do know  ;D please enlighten me as to why it's not a good idea using an egg.
Thats not one I heard of, I don't have a oil cooler but I'll bear it in mind. :D
« Reply #26 on: 08 November 2015, 20:47:59 »
I'm not knowledgable enough to explain it to you, but I know someone who is. He'll probably pick up on this sometime next week. Get you tin hat out.  ;D
Vicar
  • staffs border
    • 2.0 CD
« Reply #27 on: 08 November 2015, 21:12:09 »
Ok so the jury is out on the egg sealant..  ;)
I would still check the stat, even if you got a new one recently, check it's working? 8)
Thats not talking "dangle berries"
« Reply #28 on: 08 November 2015, 21:22:43 »
Actually you do have an oil cooler... sits between the filter and the block and has two coolant pipes connected to it... ::)
I would probably stick to cooking :-*
Vicar
  • staffs border
    • 2.0 CD
« Reply #29 on: 08 November 2015, 21:37:19 »
Fair enough. I thought the one mentioned before was to do with the auto gearboxes.
Everyday is a school day.  ;D
Pages: 1 [2] 3 4  All   Go Up
