Pages: 1 [2] 3  All   Go Down
Author Topic: Can I use a 2.5 radiato on a 2.0?  (Read 9575 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Can I use a 2.5 radiato on a 2.0?
« Reply #15 on: 24 November 2015, 17:21:39 »
My 2.2 four pot was losing coolant. Changing head gasket has cured that. This 2.0 has been losing coolant somewhere. I have found a pinhole in radiator header tank at top near top hose pipe. I changed radiator for a 2.5 radiator, which then lost coolant via a crack in almost the same place. Compression test shows all 4 cylinders about 12.5 bar. Now looks like radiator to me, easy cure. I think you are agreeing, Al. Am I right?
« Reply #16 on: 24 November 2015, 17:28:18 »
Indeedy ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #17 on: 28 November 2015, 08:55:14 »
Am fitting new radiator. I have transferred the sensor plugs and fan from the original radiator, but find I have 2 12mm id threaded holes on radiator right hand tank which were not on the original radiator, or indeed on the 2.5 rad, How do I plug them?
steve6367
« Reply #18 on: 28 November 2015, 09:37:21 »
Unused internal gearbox fluid cooler? If so no need to block.
« Reply #19 on: 28 November 2015, 09:43:03 »
Exactly :y
terry paget
    • 3 Astras 2 Vectra
« Reply #20 on: 28 November 2015, 09:57:11 »
Thank you.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #21 on: 28 November 2015, 11:07:39 »
Stick some duct tape over the holes to keep dirt out of the cooler. Just in case you need to reuse the radiator on an automatic car.
« Reply #22 on: 28 November 2015, 11:12:23 »
If they are present you can leave the plastic bungs in place, just visible in pic (note only top fitting visible bit there are definitely two ;)). Alternatively for piece of mind, a suitable bolt cut short will plug the holes, but really isn't necessary. Put this way, if anything comes out of those holes, you need a new radiator ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #23 on: 29 November 2015, 06:56:57 »
Job done, all OK, holding coolant, no leaks. Looks like it was not head gasket after all. My thanks to all.
steve6367
« Reply #24 on: 29 November 2015, 09:55:38 »
Good news  :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #25 on: 01 December 2015, 08:29:48 »
I've had 2 radiators failed in the same way with the tank cracking on the top hose side, I'm convinced they go brittle with age/use.
Strangely enough, I had also salvaged a spare from a car I'd scrapped and only found out it was cracked when I needed to use it. A new one was my solution too  :)
terry paget
    • 3 Astras 2 Vectra
« Reply #26 on: 01 December 2015, 08:56:34 »
Thanks for that sjc. It gives me added confidence in my belief that I have cured my car. I have more radiators in my spares pile, I guess they are all junk too. At £50 for a new radiator it's obvious, at Vx prices (£160?) it's not.
terry paget
    • 3 Astras 2 Vectra
« Reply #27 on: 04 December 2015, 13:35:23 »
It has made a fool of me. This morning SWMBO took it to Tesco's  I watched its departure. It was running on three, and steaming. Apparently it steamed all the way to Tesco's, other cars hung back in alarm. Coming home it ran better. I checked water level - very low. I fear head gasket has gone after all.
steve6367
« Reply #28 on: 05 December 2015, 08:33:18 »
At least thec HG is an easy job on the 4 pot  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #29 on: 10 December 2015, 17:19:19 »
Now here's the mystery. Compression test showed all cylinders about 12 bar; conclusion, head gasket is OK. So I change the radiator for new, all seems well for a while. Last Friday wife takes car to Tesco's, firing on 3 and leaving trail of steam behind it, on examination header tank level very low. New conclusion - HG gone after all. Car not moved since then. This morning, thought I had better run engine before cylinder fills up with water and hydraulic locks, fires immediately on all 4. What is going on?
I reckon coolant only leaks into cylinder when under pressure but engine not running, i.e. on hot stop. Left for 6 days the coolant  drains past the rings into the sump, then starts on all 4.
Any more ideas?
Pages: 1 [2] 3  All   Go Up
