Inspection of the Contitech belt kit reveals...
Started by Webby the Bear, 09 November 2015, 10:59:46
Webby the Bear
yeah pretty sure it said skf. but ill get the numbers in a bit :)
RIP Paul Lovejoy
Webby the Bear
So here's the video of the play (ignore swmbo and ma talking about sofas in the background  ;D)
its the portion in the middle that's clicking as you can see on the video. that may not even be the bearing. I don't know. but either wat i'm calling it shagged!
RIP Paul Lovejoy
Webby the Bear
....and a pic of the bits of baked on belt in comparison with the other one. its like this all around the pulley  :y
RIP Paul Lovejoy
Gaffers
Gaffers
Quote from: Webby the Bear on 09 November 2015, 18:11:56
I wonder if that is from the old belt.  I have noticed when a belt rubs or gets damaged on the outer edge the bits accumulate by the bottom pulley.  If left behind it would be easy for some to fall on to it and then be pressed on to the metal.  That may explain the squeeking but not the clicking.
Webby the Bear
Could well be guff. But that play in the centre eccentric portion is not right, bloody glad I changed it  :y
RIP Paul Lovejoy
But Gates, Contitech and SKF kits all use the French made SKF bearings.  AS I've said before fitted 5 or 6 Contitech kits over the years without any issue, although latest kit fitted to Estate was a Gates (only because it was available about 6 months before for about £35), and again no issues with this to date.
Quote from: Webby the Bear on 10 November 2015, 19:18:42
As already said, it might be right.....did you get the bearing number?
Webby the Bear
Quote from: dbug on 10 November 2015, 23:53:17
That's fine. it's not a thread to try and harm Contitech sales. Just showing evidence of what potentially may have cost me another set of cylinder heads  :y
RIP Paul Lovejoy
I think that all the belt kits I've seen use SKF bearings, even the £60 Dayco kit on Amazon.  :-\
Webby the Bear
Quote from: Marks DTM Calib on 11 November 2015, 09:38:52
I'm confident its not right. But.....
Numbers stamped on the pulley of the one with play:
on the outer pulley edge - SKF - J037 11:53 - 337185A - FRANCE - 90573616
on the maroon ball bearing cover - 0853
RIP Paul Lovejoy
