Author Topic: Lights-on buzzer...  (Read 2627 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Lights-on buzzer...
« on: 09 November 2015, 14:39:26 »
...what's it supposed to sound like? And where is it? I genuinely can't recall hearing it, but my working life is an endless array of warning buzzers, bongs and beeps, so they don't normally work on me anyway.
This is in no related to another forum member having left the MV6s lights on and flattening the battery, obviously.
I'm just curious if mine has gone faulty - assume it's operated off the door switch, same as the interior lights - which seem to be working fine.
Also helps if you turn the battery charger on when you leave it to top up
Re: Lights-on buzzer...
« Reply #1 on: 09 November 2015, 14:58:46 »
Should be behind the glovebox although some post `98 were incorporated in the main lightswitch. A faulty drivers door switch will also cause the same problem
« Reply #2 on: 09 November 2015, 15:47:33 »
Open the drivers door, key out, and turn the lights on... Should hear a very annoying, high pitched squealy boingy noise :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #3 on: 09 November 2015, 17:00:18 »
If it,s working you will certainly hear it and it doesn,t take long to totally pish you off :y
« Reply #4 on: 09 November 2015, 19:40:07 »
Definitely not working then, ta chaps!
Question is, is it easier to find and fix the fault... Or train said member to not leave the lights on when she's finished...  ;D
« Reply #5 on: 09 November 2015, 20:49:46 »
On later models the relay is sometimes under the dash
Lower white one in pic
