Author Topic: management light  (Read 7594 times)
aiden
  • middx
    • omega cdx estate
Re: management light
« Reply #15 on: 24 November 2015, 17:40:41 »
car has been running ok all week failed twice but starts up ok and runs, so every thing must be connected
edgi
  • leeds
    • omega 2.5 v6 elite
« Reply #16 on: 24 November 2015, 17:50:34 »
Sounds like it could be egr on its way out, starts off cutting out randomly now and again then over time gets worse, although this generally happens when your coming to a stop, need to clear the codes with any diagnostic tool that has that feature, drive the car for a few days and see if management light comes on and recheck 'stored' fault codes to see if any have been logged but not put the management light on. this will give you a clearer idea of what is going on.
cheers
aiden
  • middx
    • omega cdx estate
« Reply #17 on: 28 November 2015, 10:39:23 »
if I blank off EGR do I  disconnect it as well
« Reply #18 on: 28 November 2015, 10:51:52 »
Only if you want to keep the light on... ::)
Needs to be connected so that the Ecu thinks it's working as it should :y
aiden
  • middx
    • omega cdx estate
« Reply #19 on: 28 November 2015, 11:35:49 »
blanked it off , now see if its fixed the prob, thanks all :)
aiden
  • middx
    • omega cdx estate
« Reply #20 on: 28 November 2015, 14:08:10 »
since I disconnected the battery it shows 100 more miles on computer than it should , I there a way to reset it
aiden
  • middx
    • omega cdx estate
« Reply #21 on: 28 November 2015, 16:38:16 »
update,   went for a run about 5 miles pulled up engine cut out, started after 5 mins returned home pulled up and kept running, so whats next
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22 on: 28 November 2015, 18:18:16 »
MAF sensor. The next time it happens, disconnect the MAF, and see if the engine runs. This will put the EML on, but it will extinguish if you reconnect the MAF. The bad news is that a new MAF is quite a costly part.
