Pages: 1 2 [3]  All   Go Down
Author Topic: whats this likely to be then chaps ?  (Read 9683 times)
Re: whats this likely to be then chaps ?
« Reply #30 on: 14 November 2015, 08:48:58 »
I'm nearby at the moment with a code reader that might read codes for you... PM incoming
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« Reply #31 on: 29 November 2015, 18:37:25 »
Right, so 2 weeks have gone by and no problems, but today the light came on again.
No symptons at all from performance, no limp mode, nothing flashing just normal.
Got home switched off, switched back on again and light now out.
Any ideas chaps, I would like to nip this in the bud before it lets me down?
Had codes read after last time it happened but nothing found or stored, pedal trick wont work on this car, all lights near gear selector working normally.
Is it time to do cam sensor do you reckon or can I check anything else first?
« Reply #32 on: 29 November 2015, 18:56:09 »
If no misfire/rough idling, and everything else apparently fine, the yes, it's most likely the cam sensor... won't actually leave you stranded, but it will potentially require alot of cranking to fire... this being the acid test along with no other information as to the problem...
Only buy from a genuine VX dealer that you genuinely have to go to... Go Vauxhall in Burgess Hill is probably the nearest currently  :y
amazonian
« Reply #33 on: 29 November 2015, 19:07:47 »
Cheers Al, I will get one this week then and see what happens.
Pages: 1 2 [3]  All   Go Up
