Author Topic: Handbrake q...  (Read 8800 times)
Handbrake q...
« on: 17 November 2015, 12:06:28 »
Hand brake release/return spring? Mot item?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Handbrake q...
« Reply #1 on: 17 November 2015, 12:25:04 »
Well, the H/B needs to release so yes. But it's hardly a precision part, so you must be able to find something suitable. Even if that means robbing one off your other cars.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Handbrake q...
« Reply #2 on: 17 November 2015, 12:35:18 »
Definitely yes  :y
I know because i've been failed on a week spring before  >:(
Diamond Black Geezer
    • & a silly coupe coming...
Re: Handbrake q...
« Reply #3 on: 17 November 2015, 13:05:16 »
I've seen many a spring adapted to work, however, no idea what Vx would charge, but can't imagine being the earth. How soon were you requiring it? (hoping to christ that they won't have to special order it in from Germany and t takes as long as a windscreen to get here  ::) )
Re: Handbrake q...
« Reply #4 on: 17 November 2015, 13:27:33 »
Ta :y suspected as much...
Typically, the weather has gone from shit to horrific ::)
Re: Handbrake q...
« Reply #5 on: 17 November 2015, 13:44:49 »
But on the bright side, the instant you walk indoors, take off the soaking clothes and break our the swarfega, the sun will break out and immediately become unseasonably brilliant and warm. This is how weather works.  :)
I say we vote an OOFer once every week to do a pain of a job, in the foulest of weather. The instant they're finished, the weather will go lovely - as is sod's law - and the rest of us can then rush outside and do our wishbones, idler arms, handbrake shoe change, rear bearings, cambelts in sunshine and warmth!
Hope you get sorted soon.
Re: Handbrake q...
« Reply #6 on: 17 November 2015, 16:43:28 »
As an aside, should there be one on each side?
I nicked the nearside one with a grinder, don't ask, and have subsequently discovered that offside doesn't have one...
Guessing I need to buy two ::)
  • Chatham, Kent
Re: Handbrake q...
« Reply #7 on: 17 November 2015, 16:49:01 »
For the full effect, you need to make them start a job just before it gets dark so that they finish at 02:49 hours. At which point there is a power cut so a nice warm shower isn't a possibility.
Count me out of this, by the way, I've done far worse professionally and you couldn't stomach the swearing ;D
Re: Handbrake q...
« Reply #8 on: 17 November 2015, 16:50:23 »
You'll probably find Vx sells the springs in packs of 5 or something...  ::)
  • Chatham, Kent
Re: Handbrake q...
« Reply #9 on: 17 November 2015, 17:21:32 »
Or, they are £0.27 each. But, of the two that are left in the worldwide parts system, one is in Worthing and the other was accidentally sent to Easter Island and will be another 3weeks.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Handbrake q...
« Reply #10 on: 17 November 2015, 17:27:26 »
They are handed left and right, left hand is sod to get off and I usually cut it off to save time.
Re: Handbrake q...
« Reply #11 on: 18 November 2015, 09:55:11 »
Oh, they ruddy would be!
Re: Handbrake q...
« Reply #12 on: 18 November 2015, 10:25:03 »
Nothing a couple of paperclips won't solve ::)
Will pick up a fittings kit from helfrods on the way home... Spring length is almost irrelevant as I will need to drill new holes in the backing plates :-X
Re: Handbrake q...
« Reply #13 on: 18 November 2015, 10:36:47 »
Option 2 is I suppose strip down, fit new/refurbed backplates, requiring new rear bearings while you're at it, but that's turning a pig of a job into a whole field full of pigs.  :(
At least if you did go to that level you'd know the backplates won't need looking at for another 100k+  :-\
Re: Handbrake q...
« Reply #14 on: 18 November 2015, 10:52:26 »
Not going to happen... Even if I fitted new backing plates, I would still need to drill them as the holes are vanished in making clearance for the calipers... ;)
