Author Topic: Front self levelling sensor  (Read 4883 times)
Ash3383
  • Belfast
    • Omega B 2.5 v6
« on: 18 November 2015, 22:11:19 »
Was changing the wishbones on my 00 CDX omega and noticed I've a problem with my headlamp levelling sensor. The wee plastic arm connected to the metal arm that plugs into the sensor is missing. Can you buy the wee arm or do I need to purchase the entire unit?
Thanks in advance
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Front self levelling sensor
« Reply #1 on: 25 November 2015, 13:05:47 »
I bought the entire unit (223 EUR) to my 2001 model. I never understood how the plastic arm is clamped to the sensor in the original one. There was just a rubber ring which held the arm in the sensor. The new model seemed to be mechanically much better. Only problem was that also the connector type was changed in that new one so I had to cut the old wires and solder the new wires to them.  But it's working now properly.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #2 on: 25 November 2015, 13:36:04 »
You may get just the arm (though not sure Vx will sell you it, most likely from a breaker) however, if you're off down the breaker route, might as well get the whole assembly. As said above, they're not held in particularly well, have a habit of popping out.  :)
« Reply #3 on: 25 November 2015, 21:01:52 »
Get a known good unit from a scrapyard.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 26 November 2015, 04:51:41 »
Er no.
 Also bit of a short post dbg, I miss the long winded approach  ;D
Hoof'land storeman.
« Reply #5 on: 26 November 2015, 09:18:50 »
I've got less time these days .  :D  :D
Nice to be missed, though  :y
Ash3383
  • Belfast
    • Omega B 2.5 v6
« Reply #6 on: 28 November 2015, 17:53:32 »
Thank you all for the help. After weeks of searching, no joy on getting sensor for omega, but have been told vectra b is the same sensor, so have bought one today and hopefully it will work for me....
biggriffin
« Reply #7 on: 29 November 2015, 13:16:55 »
Thank you all for the help. After weeks of searching, no joy on getting sensor for omega, but have been told Vectra b is the same sensor, so have bought one today and hopefully it will work for me....
This could be worth checking, as others have same problem..
Hoof'land storeman.
« Reply #8 on: 29 November 2015, 13:40:41 »
Totally different on the Veccy B IIRC
« Reply #9 on: 29 November 2015, 13:50:42 »
Part number for replacement sensor is #93165414
The new connector has following terminal colours:
No 1 is Grey............splice with the Brown/White tracer on Omega
No 2 is not used
No 3 is not used
No 4 is  Black..........splice with the Black/Brown tracer on Omega
No 5 is  Red............splice with the Brown/Red tracer on Omega
No 6 is not used
« Reply #10 on: 30 November 2015, 08:42:26 »
I've got a single sheet of A5 paper round here somewhere, with a few lines of text, but mainly blank. It's titled 'Things RobG Doesn't Know About Omegas'  :y
There's a footnote disclaimer 'please note: the above list isn't worth knowing'  :)
« Reply #11 on: 30 November 2015, 15:21:36 »
:P :P ;D
