Pages: [1] 2 3  All   Go Down
Author Topic: Kaput LPG system  (Read 8226 times)
Kaput LPG system
« on: 20 November 2015, 16:40:16 »
I've spent the afternoon tinkering with my LPG system that suddenly stopped working a couple of days ago.  ::)  and I can't see whats wrong with it.  :-\
All the signs are that it's run out of gas, but I've got a full tank as I filled up shortly after it stopped working thinking I had an empty tank.  ::)
It runs fine on petrol and from cold will attempt to switch to gas but if driving will beep angrily at me and go straight back to petrol.  If ticking over it will simply stall.  :-\  All the pipework and wiring looks fine and I can hear a click from the general area of the vapourisor just as it attempts to switch.  :(
Any ideas?  :-\  TIA!  :y
Re: Kaput LPG system
« Reply #1 on: 20 November 2015, 18:16:57 »
Unbodge the wiring and try again ;)
« Reply #2 on: 20 November 2015, 19:35:06 »
Nope, I unpicked and checked all that and it's just as I bodged it 6 weeks ago and its worked fine so far.  ::)
« Reply #3 on: 20 November 2015, 19:58:45 »
;D you daft brush.... ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 20 November 2015, 20:36:20 »
If its bleeping at you on change over then its detected a fault somewhere, some give different bleeps as a clue to might be the fault code.
« Reply #5 on: 20 November 2015, 21:02:40 »
Do you know morse code? It might be telling you in morse code.  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 20 November 2015, 21:19:38 »
Teach ya to use forklift fuel.  ;D
Hoof'land storeman.
zirk
  • Epping Forest
« Reply #7 on: 20 November 2015, 21:53:03 »
« Reply #8 on: 20 November 2015, 22:01:37 »
« Reply #9 on: 20 November 2015, 22:02:56 »
Thanks Zirk, I didn't know that!  ::)  :y   Guess I should Please read the manual!  ;D
« Reply #10 on: 20 November 2015, 23:06:08 »
So... Make of system? Do you have the leads?
« Reply #11 on: 20 November 2015, 23:26:43 »
« Last Edit: 20 November 2015, 23:45:25 by Sir Tigger »
« Reply #12 on: 21 November 2015, 09:09:39 »
« Reply #13 on: 21 November 2015, 13:23:33 »
Yes mines the Prins VSI and has the same switch as in the photos. What I really meant is, given that it's not genuine Prins software is it worth a punt?  :-\
The other thing that has occurred to me today is that the filter hasn't been changed for ages so that might be clogged, but would that cause a sudden shut down?  :-\
« Reply #14 on: 21 November 2015, 21:48:04 »
Worth a punt? How much are you willing to lose? Without diagnostics you are urinating in a strong breeze until you find the fault ;)
Unlikely to be filter..l mines done over 57k on LPG now without a filter change :-[ ::)
Pages: [1] 2 3  All   Go Up
