Author Topic: heater  (Read 2480 times)
flyer 0712
heater
« on: 21 November 2015, 10:09:53 »
during the summer my desmond had head gasket replaced...then he heater didnt work very well so bled the system as per advice and it was fine...but now as temperatures drop so does the heat inside the cabin,,so much so that it blows warm only..tried the reset flaps yesterday and that made it blow stone cold afterwards.thermostat was replaced and although takes ages to come up to temp does appear once hot to run around 88 degrees...top heater matrix hose gets hot but bottom hose is only half the heat(not very warm at all )...matrix was flushed at time of head gasket...so was thinking of replacing heater matrix..the cheat way...on the advice is says,disconnect the heater hoses under the bonnet from the matrix,,,,then from inside the cab take torx off the bracket that holds steel pipes that go into matrix.....so do you have to disconnect from under bonnet to be able to pull inside pipes back enough to clear the matrix..thanks...
