Author Topic: LPG switching off  (Read 14565 times)
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
Re: LPG switching off
« Reply #30 on: 26 November 2015, 18:40:43 »
....and you have a usb to serial converter in the lead?
Plus driver, or no connection will be made.
Sorry if I am butting in or wrong, but I needed one on mine....
I used to know everything. Then I got married.
b4ndit
« Reply #31 on: 26 November 2015, 19:23:51 »
yes have all of that :y
« Reply #32 on: 26 November 2015, 20:28:41 »
Hi LD, according to the stag site it is the correct version and by driver do you mean the driver for the usb lead? thanks
Yes, driver for lead.
Version varies dependent on whether it is a 300, 300 Plus or 300 Premium. Also on what Firmware is on it already.
b4ndit
« Reply #33 on: 26 November 2015, 20:46:18 »
thanks going to have another go tomorrow and see what hapens :y
« Reply #34 on: 26 November 2015, 22:31:16 »
I'm guessing you don't have the laptop from setting it up?
b4ndit
« Reply #35 on: 26 November 2015, 22:44:52 »
No that laptop went kaput so have a different one now
« Reply #36 on: 26 November 2015, 22:51:55 »
Shame. I would guess that you need a different version of the software and it will connect ok.
b4ndit
« Reply #37 on: 27 November 2015, 11:34:37 »
Update I have tried to connect to the  lpg system again this morning and so far have had no luck at all I have updated the driver for the lead and have the latest software version but  it still says no lpg controller any help much appreciated thanks :y
« Reply #38 on: 27 November 2015, 11:45:55 »
If you look in Device Manager on the PC, the LPG cable should appear as a COM port under "Ports (COM & LPT)" when it is connected. If that doesn't happen, then the device driver has a problem.
Once you get that far, the LPG software should find the ECU automatically, but you can set the COM port number in the software to force it to use the correct port.
If it still doesn't find the ECU, then I'd suggest that the software is the wrong version for the firmware on the ECU.
The earliest Stag 300s were never updated beyond version 1.14.1.0 and will communicate with nothing else. This version is in a separate section of the download page: http://www.ac.com.pl/en/doc/346/instructions-software.
b4ndit
« Reply #39 on: 27 November 2015, 12:14:35 »
Thanks Kevin that's the version I have will double check the com port again and see if it makes any difference :y
b4ndit
« Reply #40 on: 27 November 2015, 12:24:19 »
just tried the lead and it finds it no problem but will still not talk to the gas ecu getting to the end of my tether with this system will have to put it into an lpg installer and see if they can sort it if not its coming off thanks for the help off everyone :y :y
« Reply #41 on: 27 November 2015, 12:27:45 »
Just stay below 60. Most blokes your age do.  :-X
« Reply #42 on: 27 November 2015, 12:30:06 »
Degrees or MPH?
« Reply #43 on: 27 November 2015, 12:34:31 »
Degrees or MPH?
KPH mostly.  :(
b4ndit
« Reply #44 on: 27 November 2015, 13:03:41 »
I will do when I reach your age ;D ;)
Pages: 1 2 [3] 4  All   Go Up
