Author Topic: Winter tyres  (Read 4283 times)
Ady
  • Poole
    • Omega 2.6
Winter tyres
« on: 25 November 2015, 16:30:38 »
Hello everyone
A friend has given me some winter tyres.
They are 215 65 16 and I'm currently running 225 55 16 on standard CDX 2002 alloy wheels.
Has anybody tried this size out on an omega, will I get away with running them for the winter?  Or will the narrow but deeper tyre be a nightmare drive?
Also would I fit them on the front or the rear? I'm inclined to fit them on the front as braking and steering is more important than a bit of sideways panic on the early morning frosty commute.
Thanks
I would just buy new tyres but I'm skint  :'(
Re: Winter tyres
« Reply #1 on: 25 November 2015, 19:26:04 »
Fit to all four wheels or don't bother...
https://youtu.be/K7xXDMkVFlE
As for that size...
The overall diameter is nearly an inch and a half greater...
http://www.miata.net/cgi-bin/tirescgi
Really wouldn't recommend it, skint or not :-X
« Last Edit: 25 November 2015, 19:42:42 by Harris K Telemacher »
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Winter tyres
« Reply #2 on: 25 November 2015, 19:34:03 »
Hello
I believed that an important thing here is the load index of the tires. In my owners manual (car bought here in Finland, which belongs to EU) following tyres are recommended:
195/65R15 91V
205/65R15 94V
225/55R16 94V
235/45R17 93V
Lowest load index here is 91 which means (table found in internet) 615 kg/tyre. According to the owners manual max axle loads are 1080 kg in front and 1155 kg in rear. Seems to be logical if I understood it correctly. So perhaps the tires with too low load index are not safe.
On the other hand that size seems quite big in diameter (if my calculation is right, usually not) about 686 mm while your 225/55/16 are about 654 mm. If there is space enough then they can rotate; how about ABS or TC when there is diameter difference between front and rear axle? However, I prefer to have winter tires in all four wheels (and with spikes in Finland, too).
195   205   225   235   215
65   65   55   45   65
15   15   16   17   16
381   381   406,4 431,8 406,4
634,5 647,5 653,9 643,3 685,9
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Winter tyres
« Reply #3 on: 25 November 2015, 19:42:45 »
Winter tyres on dorset :o
Hoof'land storeman.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Winter tyres
« Reply #4 on: 25 November 2015, 19:51:30 »
Why do we all[in England at any rate]suddenly need winter tyres? ???
Re: Winter tyres
« Reply #5 on: 25 November 2015, 19:55:45 »
We don't have to have them and I've go no intention of fitting them. But.......they are much safer.
Re: Winter tyres
« Reply #6 on: 25 November 2015, 20:00:11 »
Yep. We seem to have managed for decades without them.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Winter tyres
« Reply #7 on: 25 November 2015, 20:16:27 »
Probably something to do with all the bloody safety systems.  Traction Control/ESP and ABS systems cutting in all the time not allowing the experienced driver to do 'the right thing' in adverse weather conditions.
Give ma a Morris Minor over a modern car anyday for driving in snow.... except for maybe the heater!  ::)
Re: Winter tyres
« Reply #8 on: 25 November 2015, 20:19:19 »
I knew it! Morris minor...yes   ;D
Re: Winter tyres
« Reply #9 on: 25 November 2015, 20:57:00 »
It would certainly be quicker than his arthritic old Saab. :)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Winter tyres
« Reply #10 on: 25 November 2015, 21:14:07 »
In the snow, you are most probably correct.  Can't drive a FWD car against the handbrake for starters.  Add to the fact that 295BHP and 450N-m can be quite a handful in the dry when 'making progress'.
How's that underpowered, overweight V6 doing?  :P :y
JoeRadosavljevich
  • Serbia
    • '94 LPG'd Omega 2.0 16V
Re: Winter tyres
« Reply #11 on: 28 November 2015, 20:09:03 »
That chick is nice
