Author Topic: Crank sensor  (Read 2843 times)
martin341
  • Finland
  • I do my own stunts.
    • '00 3,0 MV6, '00 2,5 V6
Crank sensor
« on: 30 November 2015, 17:08:46 »
So as the symptoms are starting to occure thought its time to too the crank sensor change...until i got under there to check which one it is. Some egghead apparentli has done it once before with a AFTERMARKET sensor :'( >:(  So how the hell to i find out now what was installed there from the factory? Or should i just bite the bullet and just pick one? The car in question is my 3L v6 year 2000, April with vin: W0L0VBF35Y1139368 if that helps ::) Maybe AndyC or RobG or someone can work their magic :D
A pic of what is installed at the moment:
http://postimg.org/gallery/13gd8rrra/
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Crank sensor
« Reply #1 on: 30 November 2015, 17:16:03 »
You need to follow the wiring from the sensor up to where it plugs into the wiring loom, and examine the plug. This will give a better idea of which sensor you need. They all look very similar at the engine end.
The advice for a genuine GM sensor is because the durability of pattern ones can be variable and in the UK the cost saving isn't enough to justify. That may be different where you are.
Re: Crank sensor
« Reply #2 on: 30 November 2015, 17:18:19 »
With your model year I`d hazard a guess at 'Bosch' 90540743
martin341
  • Finland
Re: Crank sensor
« Reply #3 on: 30 November 2015, 17:28:30 »
Then Bosch it will be :y it's a bit cheaper also LOL. Thanks
Re: Crank sensor
« Reply #4 on: 30 November 2015, 17:30:45 »
The majority of Bosch badged sensors out there are fake, Get from reputable source.
martin341
  • Finland
Re: Crank sensor
« Reply #5 on: 30 November 2015, 17:57:04 »
I will order from Opel stealer...
Re: Crank sensor
« Reply #6 on: 30 November 2015, 19:00:10 »
Sensible choice :y
martin341
  • Finland
Re: Crank sensor
« Reply #7 on: 03 December 2015, 17:03:27 »
So checked Codes via paperclip and got a 19. Think that confirms the case. New sensor allready waiting at stealers and it's friday tomorrow :y
Re: Crank sensor
« Reply #8 on: 03 December 2015, 20:15:16 »
Yup, looks like the best way forward - symptoms and codes now match
