Author Topic: Camber...  (Read 2146 times)
Camber...
« on: 01 December 2015, 10:29:06 »
Nearside 1degree 18'
Offside 2degrees 32' at maximum adjustment...
Best solution... Either open the slot out a smidgen or fit a slightly thinner bolt?
Considering running a round file across the outboard edge... Question being, how much to remove?
Thinking 0.5 mm :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Camber...
« Reply #1 on: 01 December 2015, 10:44:56 »
Thinking back to when I adjusted mine, there was several degrees of adjustment, from positive to that looks broken negative. So, not wanting to teach you to suck eggs; you have loosened both bolts? The holes/slots aren't crudded up? The bolts are straight? There's probably more but hopefully you get my point.
Otherwise a round file, leaving about half the bolt diameter at the edges of the part should do.
Re: Camber...
« Reply #2 on: 01 December 2015, 11:41:40 »
I set it by eye when I rebuilt it, was at garage having alignment done and they were the ones adjusting it, so might have a point re lower bolt...
Bolts are true and holes clean :y
Currently drives nicely but needs new front pads soon, so will tackle it then... ;)
Re: Camber...
« Reply #3 on: 01 December 2015, 18:25:51 »
Settings...
Rear wasn't touched as both adjusters seized solid and one track rod has a distinct curve to it...
Osf camber needs work, although it did improve slightly as the toe was set.
