Author Topic: Fuel consumption  (Read 6531 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Fuel consumption
« Reply #15 on: 03 December 2015, 18:33:55 »
Oh no!!!! Don't get Webby started on 0-60 times :D :D :D ;D
« Reply #16 on: 03 December 2015, 18:48:59 »
I could post up over 5 yrs of data from my 3.0 auto, admittedly on LPG (so you'd need to add approx. 15%)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #17 on: 03 December 2015, 20:13:26 »
OP - have a similar issue myself (though no 3.0 to compare it with, unlike yourself!  :))
Out of interest zirk, what will changing the MAF prove? Thought the MAFs weren't ever an issue on 2.5s always seeming bulletproof, only the later V6s for some reason seem to fail?
Check out my 'Stats' thread OP for some more info, if it helps  :)
It would prove its not a MAF problem, OP has almost like for like sitting on the drive so fairly easy to swop them over and see if the issue moves.
The MAF's don't always just fail, they can deteriorate over a time, feeding wrong info to the ECU.
« Reply #18 on: 03 December 2015, 20:19:25 »
Generally, 2.5/3.0 MAFs either work, or are catastrophically wrong.  But there can always be exceptions, so if a spare exists on a convenient donor :y.
2.6/3.2 MAFs by comparison do tend to deteriorate rather than fail catastrophically.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #19 on: 04 December 2015, 07:55:22 »
My two 2.5CDX manual saloons give about 29.5mpg over 2000 miles of mixed driving, my 2.2 manual saloon only gave 27.0mpg over a similar mileage. As discussed on different thread, earlier engines are more efficient.
terry paget
    • 3 Astras 2 Vectra
« Reply #20 on: 04 December 2015, 08:06:47 »
Corection: the 2.5s are estates.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #21 on: 04 December 2015, 09:03:15 »
oh if its sitting there, well worth the 5 minute swap it is, agreed.  :y
Just checking if there'd be much point before I started to go hunting around for a spare MAF, that's all :). Worth it if you've already got a spare, though, quite agree.
zirk
  • Epping Forest
« Reply #22 on: 04 December 2015, 09:54:38 »
Strangely enough, Ive had 2 Maf's go, both on 3.0 MV6's, one gave up the ghost overnight and other was causing issues until I swapped it out.  I yet to have Maf go on a 2.6/3.2.:-\
Having said, Ive yet to have a Crank Sensor or Oil Cooler go on 3.0, they've all been on 2.6/3.2.   :-\ :-\
