Author Topic: P1555 code ?????  (Read 8979 times)
glenny73
  • Swanscombe
    • 2.2 cd 2003
Re: P1555 code ?????
« Reply #15 on: 15 December 2015, 22:19:14 »
Done that light comes on still  :y
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #16 on: 16 December 2015, 00:54:38 »
Mine is doing exactly the same, even went on holiday (France) with it happening and nothing seemed to being effected by it
at least read the last entry in here
http://www.omegaowners.com/forum/index.php?topic=130904.0
I am still of the opinion that it is Fuel trim + CAT or Lamba or exhaust flow related .
Note - pre-cat has been removed since and code still there
I will someday get round to replacing both lamba's with new from GM but expensive, after that the CAT
glenny73
  • Swanscombe
    • 2.2 cd 2003
« Reply #17 on: 16 December 2015, 13:10:56 »
Hi again done the cable tie on plug but broke down yesterday my fault plug was not connected properly I lost throttle call rac out I could not believe I done it but he tried to clear code but coming up with p0700 transmission something he explained saying gearbox transmission module  range any ideas car seems ok but can't clear code thanks glenn
« Last Edit: 16 December 2015, 13:13:42 by glenny73 »
« Reply #18 on: 16 December 2015, 17:20:08 »
Finally...  A spurious gearbox code... Fit a new genuine cam sensor that you have physically and personally acquired from an actual Vauxhall dealer. And report back :y
« Reply #19 on: 16 December 2015, 18:19:51 »
Get gearbox ECU read for codes.
glenny73
  • Swanscombe
    • 2.2 cd 2003
« Reply #20 on: 16 December 2015, 23:34:38 »
Is car ok to drive it seems ok how come rac didn't read gearbox ecu
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #21 on: 16 December 2015, 23:46:50 »
That code suggests the car just needed to pee ::)
« Reply #22 on: 16 December 2015, 23:55:02 »
Yes and because they are special  ;)
glenny73
  • Swanscombe
    • 2.2 cd 2003
« Reply #23 on: 17 December 2015, 21:37:33 »
thinking of getting rid of omega for another I can't be going on with these issues and don't understand what's going on  I'm not mechanically minded just be easier ?? why this code has come up and if gearbox is on its way out then so be it  >:(
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #24 on: 17 December 2015, 22:31:29 »
Dense as I am, even I can deduce from answers on here that it may well be that the cam sensor was changed and an after market one fitted shortly before you got the car. Unfortunately you may have to fit a genuine VX one to eliminate this as the fault. Your choice. :y
SIR Philbutt
    • PJB Home Services
« Reply #25 on: 18 December 2015, 00:23:50 »
Sorry to contradict but most of the time it's when the throttle body is cleaned. Go figure  ::)
« Reply #26 on: 18 December 2015, 17:04:00 »
How did you deduce that?
You ideally need the gearbox codes read. Don't bother with breakdown outfits, they are simply there to get you home when it breaks.
Is there a local member who could read your codes properly?
glenny73
  • Swanscombe
    • 2.2 cd 2003
« Reply #27 on: 21 December 2015, 18:17:49 »
I don't know help any local code readers  :y
