Author Topic: Battery Holder for Remote  (Read 3116 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 09 December 2015, 19:11:17 »
Hello
Ordered from Locksmith repair kits for my two remotes. After soldering of all six micro switches I found that one leg of one battery holder is broken. Locksmith do not sell them, only provide under repair service. Does anyone know where to buy those?
Re: Battery Holder for Remote
« Reply #1 on: 09 December 2015, 19:15:33 »
If all else fails, buy a cheap key off eBay and take it from that.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 09 December 2015, 20:37:26 »
Use some tin copper wire and re solder it.
polilara
  • Finland
« Reply #3 on: 10 December 2015, 14:09:16 »
OK, might be easiest solution.
zirk
  • Epping Forest
« Reply #4 on: 10 December 2015, 15:54:16 »
If you don't have any tin copper wire, inner solid coax etc, just strip some stranded wire (mains cable or something) and use a few strands twisted together, as long as the solder has flown through it, it we be fine.  ;)
polilara
  • Finland
« Reply #5 on: 10 December 2015, 17:29:09 »
Thanks, I just completed it. I used small wire of one electronic component (resistor). Got a very good joint. It just did not came to my mind that I can use this wire like a carrier for the solder to flow through the hole and catch the broken leg. Thanks again!
zirk
  • Epping Forest
« Reply #6 on: 10 December 2015, 17:43:28 »
Glad its sorted.  :y
