Electrics question
Started by RobG, 15 December 2015, 16:39:33
Neutral terminal on the LOAD side was knackered. Common fault due to heavy use the pull switch is subject to. Happens less often with a quality branded switch fitted
People kill these switches as they use them to switch the shower load on and off, they are designed as an isolator only......and in fact should only need to be used for maintenance purposes.
