Author Topic: Elite rear shocks  (Read 4834 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
Elite rear shocks
« on: 17 December 2015, 14:32:01 »
Hi all,  i have a 2.6 elite with self leveling shocks on the rear.  I have tried to get replacements but i have been told it will have to be the main dealer.  Does anyone know of an alternative stockist?  Thanks
Diamond Black Geezer
    • & a silly coupe coming...
Re: Elite rear shocks
« Reply #1 on: 17 December 2015, 14:37:24 »
As far as I'm aware it's main dealer only. There are Carlton manual air adjust ones out there. (so you'd still retain the heigh adjustable, but require a foot pump)
Most people just replace with standard Boge, Sachs, Bilstein etc.. Same for Senators, which had a similar adjustable setup, just replace with standard.  :(
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 17 December 2015, 15:07:45 »
Try "Allgerman parts" also try "autovaux" both sell self leveling shocks.
Hoof'land storeman.
  • Online Online
« Reply #3 on: 17 December 2015, 20:01:51 »
.. Same for Senators, which had a similar adjustable setup, ....
You're still confusing 'ride control' with self levelling.  ;)
« Reply #4 on: 18 December 2015, 10:34:03 »
Ok, it's 'similar' - That which is not the same as, but broadly speaking has commonalities in theme. An adjustable thingygummy on old Vauxhall Saloon suspension  :D
In the context what I was saying that most people replace the Elite's rear shocks with standard, in the same way that people tend to for the Senators.  :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 18 December 2015, 10:43:39 »
Although any cost saving is eliminated by having to buy new springs.
« Reply #6 on: 18 December 2015, 10:45:49 »
No idea what you mean, Nick? New? is that like that stuff they have in boxes in shops? If the stuff I buy doesn't have surface rust or a film of oil over it, I don't trust it!  :D
  • Chatham, Kent
« Reply #7 on: 18 December 2015, 10:54:12 »
Does that also apply to consumable parts? And when the youngest of these cars is 11years old, there is a very fine line between parts that are used and parts that are used up.
« Reply #8 on: 18 December 2015, 11:02:56 »
Fair enough. Hence I look for low mileage on things where possible. Ok, I was making a joke of it; as you know, practically all my front suspension is new, apart from the steering knuckles, a few nuts n bolts and one hub. Looking around I reckon about £90 should sort you out for a pair of shockers and springs, vs whatever the Vx/other self-levellers cost. It could be that self levellers can be had for £45 each, I don't know. I'm not against new parts at all, otherwise so much of my car wouldn't have it, and also same for genuine Vx, I use it whenever possible.  :)
« Reply #9 on: 18 December 2015, 11:09:35 »
You do waffle some shit... ::)
Decent new shocks are £55+, SL ones are just over £100 now and a set of decent springs will set you back around £120...
Basically, if the self levelling works fit new VX air shocks, if it doesn't, then replace the lot.
Simples :y
mantamania
  • Chatham, Kent
    • 2.6 Elite
« Reply #10 on: 21 December 2015, 20:43:07 »
Hi all,
thanks for your response.  I tried to get some Monroe replacements and found that they are now obsolete and those that have them in stock want more than dealers for genuine GM part.  I went and bought one from dealers £134 inc VAT
biggriffin
« Reply #11 on: 21 December 2015, 20:46:53 »
Hi all,
Should be a pair.
 you wait till teleporter reads this!
Hoof'land storeman.
  • Online Online
« Reply #12 on: 21 December 2015, 20:56:27 »
Hi all,
Should be a pair.
Sometimes though needs must. I once bought a single self levelling shocker for my face lift MKI 2.2 Carlton, IIRC it was £80-odd over 20 yrs ago and one was all I could afford.  ;)
« Reply #13 on: 21 December 2015, 22:34:23 »
Fine until it ends up upside down in a ditch... ::)
  • Online Online
« Reply #14 on: 21 December 2015, 22:45:06 »
I survived .....  :y
