BT Master Socket
Started by Mr Skrunts, 22 December 2015, 15:53:46
Can these be moved by a Non BT  installer.
In my case this would mean repositioning the incoming BT cable that hangs from the telegraph pole to the current locaction by moving the achoring/spring tension mount and actully relocating it to annother room (on the outside ) on the front (and closer to the telegraph pole)
Am wanting to do this to bring my modem into the living room and tidy all the wiring up, also in the process maybe add an extension socket, the rest of the house is covered with the use of DECT phones so no issue there.
The other question is , if I upgrade to Fibre then will the new fibre box need to be fitted next to the phone socket, or can it be installed in a different location. ( I have never looked into what is involved in a Fibre so am a complete numty regards this)  ::)  If it has to be fitted next to/instead of the master socket then would the installer move the socket to suit.
zirk
#1
No, it belongs to BT.
If its a pig tail at your end, unwind that first before you unbolt the bracket Unwind from the outside towards the bracket, as that will give you some idea how much play in the dropwire cable you need when you relocate it closer to the Pole. You normally need more slack than you think you do.  :y
Quote from: Mr Skrunts on 22 December 2015, 15:53:46
Legally, no, you can't touch anything from the master socket to outside (besides the removable bottom half of the faceplate if it's a newer split-face master socket)
Any interference before a line is terminated (test socket in NTE5, or all sockets if not NTE5) is a criminal offence until the Telecommunications Act.
Quote from: TheBoy on 22 December 2015, 17:33:10
Until the telecommunications act does what....exactly?  ;D
Quote from: STEMO on 22 December 2015, 18:09:02
Stops people buggering up their lines ;D
YZ250
My master socket was in a cupboard so when BT installed infinity my signal was crap. After monitoring it BT agreed the signal was crap and agreed to move it. I ran new cable, at my expense, to where I wanted it (sitting room) but did not wire anything up. The BT engineer turned up, I explained what I'd done, he wired up the master socket and then connected the other end of my cable to the main line in.  :y
Easy job for him as I'd done all the routing of cable to keep it out of sight. He did say that my cable may not be up to BT spec, until I showed him the packaging with BT on it. He was happy when he realised that I'd done it to help him.
YZ - having once been a BT phone engr, I would have appreciated that, and would have connected it if the cable was decent.  Even 25yrs ago, the quality of cheap cable was shocking. I dread to think how bad it can get now that egay has been invented.
Cheers every one, it's confirmed what I was thinking. :y
Probably worth fitting the split-face master socket (I believe they are plug in once the screws are removed)
Quote from: Mr Skrunts on 22 December 2015, 18:39:50
Known as an interstitial VDSL NTE5
Gaffers
Quote from: VXL V6 on 22 December 2015, 18:48:32
I have a  cream you can have for that ;D
#11
There are two acronyms to look out for with fibre upgrades FTTP (fibre to the premises) and FTTC (fibre to the cabinet). I may be wrong (probably am) but I don't think BT are giving home owners FTTP as it is much easier for them to install fibre to the roadside cabinets and not take fibre into individual houses.
The upgrade happens in the cabinet so your master socket remains the same (or very similar).
Quote from: Andy H on 22 December 2015, 20:11:06
FTTP is available for virtually all FTTC areas, but few ISPs offer it. The Openreach product is FTTP On Demand.
The wholesale price to your ISP is "quite expensive", both activation and monthly.
If G.fast likely to come (assuming current extended trials are favourable) to all FTTC areas in the next 10yrs, and speeds predicted to ramp to 500Mbps over time, that is believed to be the future direction, rather than FTTP.
Quote from: TheBoy on 22 December 2015, 20:18:31
So does that mean the old master sockets stays? even with G.fast?
Its still being trialled, but most likely, yes.
