Author Topic: 3.2 starter  (Read 1710 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
3.2 starter
« on: 26 December 2015, 22:16:15 »
3.2 starter not working , before i change it whats the best way to check for a bad earth
 thanks
Re: 3.2 starter
« Reply #1 on: 27 December 2015, 01:12:13 »
Connect another temporary one using a heavy duty jump lead  ;)  If it works replace earth lead.
swordfish
  • manchester
Re: 3.2 starter
« Reply #2 on: 27 December 2015, 07:15:39 »
do you mean the main engine to chassis earth lead
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: 3.2 starter
« Reply #3 on: 27 December 2015, 08:08:30 »
You need a good connection between negative battery post to engine block. If in doubt connect a stout jump lead from negative post to block to check.
It could be a dead battery. It might be failed switch to solenoid, can be checked by shoving needle through the lead and measuring voltage. Almost certainly it's a failed starter. Obtain good one and fit following the guide. Mention it on this forum, someone may have one, otherwise Steve Brown at omegaspareparts, if all else fails Vauxhall.
