Electric back on
Started by SIR Philbutt, 28 December 2015, 00:20:54
As far as I know, if you're going to power up your house with a genny via a 3 pin socket on the ring main, you must switch off the main switch to isolate the house from the mains.  ;)
Otherwise you might electrocute someone working on the system 'upstream' who thinks it's dead and safe!  :o  ;)
Also worth considering the possible consequences of having a "suicide" lead lying around if it were to be accidentally plugged in. :o
Shackeng
Quote from: Kevin Wood on 01 January 2016, 15:02:20
Precisely, and with sensible use the plug in genny works well. ie, mains swich off, lead plugged in, start genny. :y
Broomies Mate
Quote from: Shackeng on 01 January 2016, 23:30:11
I think you have missed the point - If an adult, or even a young child were to pull 'that' plug, the consequences may be unthinkable.
I do it myself, I have a bloody great big Jenny, running a 240v feed.  I also (if the outage is more than a few hours) run another lead to my neighbours house.
Not sure on the power output, but it's a welder/generator, so assuming the regulators are OK, I should be looking at near 4kvA
I strongly suggest anyone looking at this as a temporary solution.....
Look at what you have plugged in to the mains - Write a list for each room.  When the power fails, go and switch off EVERYTHING which is not IMPERATIVE.
Start-up power will just kill the generator.
I can't remember the last time I had a significant power cut to be honest.  :-\
Quote from: Shackeng on 01 January 2016, 11:25:23
Mine is 1.7 Kw, runs fridge and freezers (high starting loads), boiler, TV and a few lights. Sufficient for survival. :y
If running modern electronics, like a new TV or PVR, ensure you have filters on the genny, and most are unfiltered and create "noisy"/"dirty" power which modern electronics can get quite upset over.
Quote from: Sir Tigger on 02 January 2016, 01:22:12
Ignoring those of my own making, nor can I remember one lasting more than a few hours.
But, then, when I was looking at moving, we purposely looked at a location that was less likely to be prone to flooding, as it had been problematic near where I used to live.
