Pages: 1 [2] 3  All   Go Down
Author Topic: Boogar :(  (Read 9290 times)
Re: Boogar :(
« Reply #15 on: 29 December 2015, 15:04:34 »
What state was the rest of the coil pack in? Any corrosion evident in the 'vents' :-\
Re: Boogar :(
« Reply #16 on: 29 December 2015, 15:10:20 »
None whatsoever .. tiny portion of the "end" of the plastic tube missing .. but nowhere near enough to account for all the crap I got out, and examining the "other" boots there is no "hard plastic" inside them ... so what is all this, and why is it stuck to the plug ??  Puzzled of Wooty B
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Boogar :(
« Reply #17 on: 29 December 2015, 15:26:39 »
Can you remember if the plugs were changed last or the coil pack Nige. Just wondering if it's remnants of the old coil pack.
Re: Boogar :(
« Reply #18 on: 29 December 2015, 15:30:09 »
Coil packs (both) and plugs changed at the same time ... April 2013 .. so although its a possibility - and old age memory can't rule it out - I think it unlikely ...  Old coil packs were in very poor nick .. but the splits/cracks were all on the main body if memory serves .....
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Boogar :(
« Reply #19 on: 29 December 2015, 15:36:42 »
Are those rubbery bits the remains of the boot in your plug socket?
That would explain why you struggled to get it on the plug!
The Halfords sockets are particularly prone to the boot coming loose in my experience; most of mine(for various boring reasons I've several sets) are glued in. #6 cylinder is the only one that I don't use a magnetic long plug socket on.
Re: Boogar :(
« Reply #20 on: 29 December 2015, 16:30:31 »
mnmmm this socket, Halfords kit one ...... it has no "boot" in it ... now its possible I guess, that when I did the plug change 2 years ago that the socket insert remained on the plug .... would explain the debris .. old insert gone very hard with heat ...
....  but would the coilpack actually go on the plug if the insert remained ??  .. perhaps it did and that has caused the present failure of the spring bit ??
Don't know ....   :(
Re: Boogar :(
« Reply #21 on: 29 December 2015, 16:38:59 »
Two years of that baking won't have done it any favours... Think the effect of oil on the plug, only slower...
Recent rain might have allowed water to get it, causing the rubber to swell, forcing the boot/contact apart. Remember that whilst the boot etc is designed to operate in those conditions, an unregulated part from a socket won't be...
Re: Boogar :(
« Reply #22 on: 29 December 2015, 18:27:33 »
Don't know ....   :(
I like that explanation, sounds very plausible.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Boogar :(
« Reply #23 on: 29 December 2015, 19:33:08 »
Being no 6 would that be the last one that you fitted before and maybe why you did not realise the rubber gripper was missing.
Re: Boogar :(
« Reply #24 on: 29 December 2015, 19:35:52 »
2 years on and I've never noticed the rubber gripper missing ! Socket has been used on other engines as well ...
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Boogar :(
« Reply #25 on: 29 December 2015, 19:37:26 »
The Hellfrauds SP sockets are a sod for this. To the point I use the socket and a magnet everytime.
RIP Paul Lovejoy
Re: Boogar :(
« Reply #26 on: 30 December 2015, 11:36:19 »
New coilpack and 3 new plugs fitted - would you believe a main dealer only had 4 plugs in stock ! - and all seems ok on the ramp. Coffee time then a quick test drive then finish packing the tin-tent and hitch up .. hopefully away by 2pm ... Hope you all have a good New Year .. see you on the other side
Take care whatever you do .. its pretty nasty out there ..
Nige & Chris
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Boogar :(
« Reply #27 on: 30 December 2015, 12:05:34 »
Happy New year Nige, hope its all fixed OK. :y
YZ250
Re: Boogar :(
« Reply #28 on: 30 December 2015, 12:56:09 »
Nige & Chris
Fingers crossed it's sorted then.  :y
Happy New Year Nige, and go steady with the van in this wind.
Have a good one.  :y
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Boogar :(
« Reply #29 on: 31 December 2015, 09:08:58 »
Mine has been known to have a strop if left for a while... A good thrash normally clears it.  :-X
Did you try revving it to see if the misfire stayed?
Yup and drove it round the estate for 20 minutes to try and warm it up /dry it out ..no change ..  :(
Interesting case, does anybody know whether this misfire was only when idling or also during this "round the estate for 20 minutes" tour. Still thinking my "Bad Idling Case" started Dec 27.
Pages: 1 [2] 3  All   Go Up
