Pages: [1] 2 3  All   Go Down
Author Topic: Does anyone know about FIAT cars?  (Read 9633 times)
deviator
  • Chesterfield
« on: 02 January 2016, 15:40:57 »
Apart from the obvious comments.
Seicento 2001 Abarth 1.1 sporting. 8v OHC, MPi setup.
Hello I have an intermittent misfire. My code reader reports p0352.
The problem.....
On initial cold start, it starts on 3 and within a few seconds fires up to 4.
Once warm and the car is restarted, the misfire is pretty much constant. (This makes me think heat related).
What I have tried so far.....
Swap coil packs over - No difference, still get p0352 (even after clearing code). In my mind that takes the coils out of the picture. (There are two coil packs, swapped 1&4 with 2&3)
When misfiring, I've pulled the leads (using insulated gloves), the misfire is from number 2.
Pulled plug 1 and 2, visually checked OK, in fact they look new.
Swapped plug 1 & 2. Still same fault/code.
Visually checked 1 & 2 HT leads.
Swapped lead 1 & 2. Still same fault/code.
What I am now thinking.....
Compression testing all the cylinders.
Injector fault.
Wiring fault.
The fault doesn't match the ECU failure posts I've read.
I bought the car with a suggested injector fault. So I would not be surprised if that is the problem. Searching forums, injectors are suggested, so is the ECU (see above). I've also seen mention of injector cleaner solving the problem.
I just wondered if anyone on here had any better knowledge of these cars?
tidla
  • solihull
Re: Does anyone know about FIAT cars?
« Reply #1 on: 02 January 2016, 16:37:30 »
Compression test is a good idea.
Single point injection?
tidla
  • solihull
« Reply #2 on: 02 January 2016, 16:51:41 »
Looking at the wiring diagram, the feed comes from the system relay (item with relay contacts) via a single wire which then splits to the two coils. Ecu then earths the coils thru pins 1 and 19.
  • Auckland
    • Mazda MPV
« Reply #3 on: 02 January 2016, 19:24:14 »
So is it SPI (single point injection) or MPI (multipoint injection)?
If it is SPI then it is unlikely that an injector fault could cause a misfire on one particular cylinder.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 02 January 2016, 20:54:54 »
Have you pulled plugs 3 and 4?  If so what did they look like?
tidla
  • solihull
« Reply #5 on: 02 January 2016, 22:16:17 »
(whiskey in hand)
If i remember rightly, both  plugs on the same coil 2&3 fire (wasted spark)
So swaping leads 2&3 at the coil should make no difference to the running, which would help with fault diagnosis /faulty cylinder id. ?
(edit, re read it so youve kinda done that.)
« Last Edit: 02 January 2016, 22:18:42 by tidla »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 02 January 2016, 22:53:17 »
If 2001, it should be Multi-Point Injection.  The OP even states so in the original post.
tidla
  • solihull
« Reply #7 on: 02 January 2016, 23:07:03 »
Theres a few different "types " for this model ranging from 150 to 230?
being the abarth model might make a difference to the wiring diagram.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #8 on: 02 January 2016, 23:16:22 »
It's a Seicento.  It had two engine variants...... one was a small one, the other was smaller.
The Sporting was a 1108cc SPi until MY 2000, then MPi thereafter.
Abarth meant bugger all, except for 'styling'.
« Last Edit: 02 January 2016, 23:18:13 by Broomies Mate »
tidla
  • solihull
« Reply #9 on: 02 January 2016, 23:19:39 »
tidla
  • solihull
« Reply #10 on: 02 January 2016, 23:20:50 »
The only other diagram, very similar but still single point?
deviator
  • Chesterfield
« Reply #11 on: 03 January 2016, 01:08:14 »
Thanks for the replies, it is definitely multi point injection, no if or buts. I can see 4 injectors.
I'm am aware of the wasted spark. As above I have swapped the 2 coil packs over, A runs 1&4 and B runs 2&3. Fault code still says coil pack B.
The swapping of plugs and HT leads was done between cylinder 1 & 2, hoping that if the plug and or ht lead was at fault, the code would move to coil pack A, but it didn't.
Due to the way the fault appears, I am pretty certain it is electrical. Even when it misfires, I can sometimes stop and start the engine and it may or may not bring all 4 into life.
It's a funny fault and I'm starting to lean towards the low tension leads to the coil packs, unless anyone has any other ideas? From the googling I have done, a faulty ECU isn't intermittent, it either works or not.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #12 on: 03 January 2016, 01:17:00 »
As you have read the code, I'm assuming you have reset the ECU?  Just in case there is a weird French thing going on!
As it's sticking with the same cylinder, a compression test may be in order, although unlikely to be an issue - That engine is quite bullet-proof.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #13 on: 03 January 2016, 01:21:10 »
0352 is a coil failure code,coils on that engine are prone to failure at 40-50k miles,sometimes however the coil failing can take out the ECU drivers too which will give the same code,I would replace a coil first and if doesn't work and find out much BBA reman want to check out/fix the ECU.
other rides
deviator
  • Chesterfield
« Reply #14 on: 03 January 2016, 12:11:29 »
Yes, read and reset codes all the way through. Compression test is my next, urm, test  ::) if this weather ever gives me a break.
I've read similar things and my coil packs are I believe original and at 39k. So this was my first thought. However I would have expected the code to move to the other coil pack when I swapped the two over. I didn't. I've also read about the frying of the ECU drivers, however this leads to a permanent fault, not a suspected heat related intermittent issue that I currently have.
Thanks for the replies, I appreciate all the help.
Pages: [1] 2 3  All   Go Up
