Author Topic: rear end rattle/knock.  (Read 4261 times)
Spally
  • Wisbech, Cambridgeshir.
    • Vauxhall Omega 2.2 CD
« on: 03 January 2016, 00:12:34 »
Are there any common faults re the rear end suspension set up on these cars? I have a rattle or light knock from the back whilst driving, sounds like a bush of some kind.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: rear end rattle/knock.
« Reply #1 on: 03 January 2016, 00:24:06 »
I would check the easy things first, like the rear shocks to make sure one hasn't failed, or that a pigtail hasn't broken off one of the rear springs.
Spally
« Reply #2 on: 03 January 2016, 00:44:44 »
Please excuse my ignorance but 'pigtail'? Is that the last part of the coil spring that you mean where it reduces in size to a smaller coil?
« Reply #3 on: 03 January 2016, 03:59:21 »
Yup ;)
Most likely are:
Failed shock upper mounting
Failed shock
Failing/failed rear subframe front bushes
Failed rear diff/subframe mountings
In descending order of how badly the car corners...
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #4 on: 03 January 2016, 11:03:04 »
Not trying to teach you how to suck eggs and all that but are all your boot cubby holes and spare wheel well free of anything that may be causing the rattle ?
ted_one
« Reply #5 on: 03 January 2016, 11:28:56 »
Don't want to hijack this post but.....have exactly the same problem with one of my 3.2's and as Al (HTK)has replaced most of the components mentioned,then it's got to be for me the latter i.e bushes etc, it's going to be either or all but knowing my luck it will be all of them ::)
Spally
« Reply #6 on: 03 January 2016, 19:37:04 »
Lol, no the boot is empty so ruled that out. But always worth checking. 😉
Spally
« Reply #7 on: 03 January 2016, 19:38:33 »
Yup ;)
Most likely are:
Failed shock
Thanks. I don't think the car corners too badly but it does seem to wander, although I think that may be the tracking doing that.
« Reply #8 on: 03 January 2016, 20:34:11 »
Could also be a failed exhaust rubber allow a bit more exhaust flex... Cold, grab the tail pipe and give it a good waggle... Any clonks and that's as good a place to start as any ;)
Spally
« Reply #9 on: 03 January 2016, 20:37:53 »
I know the exhaust is knocking but it's too light a sound for that.
« Reply #10 on: 03 January 2016, 20:41:02 »
Don't dismiss it out of hand.
Spally
« Reply #11 on: 03 January 2016, 22:00:28 »
Oh no of course not, always worth a check.  ;)
