Kaput laptop
Started by Sir Tigger KC, 07 January 2016, 23:53:16
Cheers TB!  :y
I'll reset it to factory install and see if that makes a difference and I did have a look at the Hirens site you recommended but got scared and ran away!  :D
I was planning on having a look at it today as it's been a miserable day, but got distracted by other stuff that cropped up.  ::)
So I finally had a little tinker with this old laptop of mine the other day and put the hard drive from another deadish laptop that was languishing at the back of a cupboard in it.  :)
No joy though as all I got was a message telling me
Boot Device Not Found
Please install an operating system on your hard disc.
Hard Disc - (3FO)
I havn't got a disc to load windows, so I put the original hard drive back in and now its been working fine!  :y  Although it can be very slow loading up a new website.  :-\
The thing that I don't understand is that the other laptop starts and boots up, but veeeereeee sloooooowleeee......  ::)  So that laptop 'sees' the hard drive but this one didn't....  :-\
Sounds like the drive was incompatible for some reason. :-\
tigers_gonads
Put the laptop back together and pug it into a monitor or tv using a hdmi or other cable and see what happens  ;)
Quote from: Sir Tigger on 18 May 2016, 01:07:20
Hard Disc - (3FO)
Modern fangled partitioning as used on modern-ish OS's, or old fashioned MBR?
Also, check in BIOS to see if that can see disk.
