Author Topic: Interior to Engine  (Read 4606 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Interior to Engine
« on: 09 January 2016, 14:40:12 »
Is there a relatively easy way to root a cable from the interior to the engine bay?
Not had a chance to look yet if there are any obvious ways or not, weather has been playing its tricks as per usual...
Re: Interior to Engine
« Reply #1 on: 09 January 2016, 14:50:51 »
Dbw have a grommet where the throttle cable used to run... Cluster out, followed by the foam lump behind it... ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 09 January 2016, 14:57:20 »
Thanks Al, That should do fine  8) :y
EMD
  • Noofhampton
    • 95t
« Reply #3 on: 09 January 2016, 15:00:11 »
We want to know what your wire is for  ;D
Omegatitis
« Reply #4 on: 09 January 2016, 15:04:16 »
Electric willy warmer...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 09 January 2016, 17:32:00 »
All in due course...  ;D :y
« Reply #6 on: 09 January 2016, 20:24:02 »
there's a grommet in the pollen filter housing too ..... just under the large cable gland :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 09 January 2016, 21:33:58 »
Good to know  :y
How do you gain access from the interior side? Don't really fancy taking the air bag out if that's whats required tbh.  :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 09 January 2016, 21:47:47 »
Send a Ferret in there tied to a piece of string.  ;)
That's what I normally do, apparently.  ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #9 on: 09 January 2016, 22:32:38 »
Got one spare lying around Zirk?  :-\  :D
« Reply #10 on: 11 January 2016, 19:07:38 »
I think I just fed a wired through from the engine bay side & fished it out from under the glove box  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 11 January 2016, 21:57:16 »
Thanks Bud :y
EMD
  • Noofhampton
    • 95t
« Reply #12 on: 31 January 2016, 23:40:20 »
You got to be done it by now  ::)
Omegatitis
