Author Topic: Lidl battery charger 13.99 and tester 2.99  (Read 10458 times)
Re: Lidl battery charger 13.99 and tester 2.99
« Reply #15 on: 13 January 2016, 18:22:42 »
Out of interest what UPS type batteries are they?
APC RBC6
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #16 on: 13 January 2016, 18:23:37 »
The slight issue with the LIDL charger is that it's not great as a trickle / maintenance charger, IMHO. You have to turn it on using the button and select a mode before it does anything.
Leave it on your battery over winter and one power cut means your battery is not protected.
It will also not even start to charge a battery whose voltage has dropped below 8 volts or so, as it can't decide if it's a 6 or 12 volt battery.
Other than that it's fine. mrs. KW's MX5 went flat over Christmas. Put that charger on once I'd used a crude old charger to get the voltage up to 12V and it recharged the battery overnight with no issues.
Was about to post the same thing, its about 9.5v on my one, anything below that its hopeless.
It's odd, as the manual implies that it will trickle charge until the battery reaches a plateau and decide what voltage it's levellling off at, but mine won't even power up, or tries to charge at 6V and immediately decides the battery's full.
Guess there's normally a reason why something's cheap!
My CTek is a better bet, although it's 12V only and only 800mA.
Mine just says error below 9.5, can't do anything with it when it goes in that state, you need to kick it with a normal charger for a while, then it works.
zirk
  • Epping Forest
« Reply #17 on: 13 January 2016, 18:32:53 »
APC RBC6
ok, the ones Ive got kicking around are these,
 http://www.criticalpowersupplies.co.uk/apc-rbc55?keyword=apc%20rbc6&utm_source=bing&utm_medium=cpc&utm_campaign=Part%20Numbers&utm_term=apc%20rbc6&utm_content=RBC%2055
They are 24v packs made up of 2 x 12v batts.
Some APC have a external battery out in addition to its internal ones, and the float charger can normally deal with both, providing the correct external bats are fitted.
EMD
  • Noofhampton
    • 95t
« Reply #18 on: 14 January 2016, 17:19:11 »
Not many battery chargers left . Picked one up as well as one of those back scrubbers window cleaner brush things  ::)
Omegatitis
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #19 on: 14 January 2016, 18:46:47 »
Useful points you have noted Kevin. It can help people decide to buy or not.
« Reply #20 on: 14 January 2016, 18:55:32 »
I've had that problem too. As you suggest, it's always handy to keep an old fashion 'dumb' charger too.
