Author Topic: FL Estate Rubbing Strips Wanted  (Read 3915 times)
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« on: 14 January 2016, 22:23:27 »
Anybody got a pair of rubbing strips for a FL Estate that run from the rear wheel arch and wrap around by the lights and the two short pieces on the tailgate in Star Silver (Z147)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: FL Estate Rubbing Strips Wanted
« Reply #1 on: 15 January 2016, 10:13:02 »
Cant help with the bits, but just to say, in any colour if prep'ed well they come up quiet well with Z147 rattle cans followed by a liqueur, mainly because the upper and lower angle on the strips throws the light off any miss match to the rest of the main panel.  ;)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #2 on: 16 January 2016, 12:11:02 »
One assumes you mean lacquer, and not booze ;D
Yes, you are right, if you prep properly, any colour can be changed, and as you say, light plays many tricks. :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 16 January 2016, 13:48:01 »
When you get your mouldings, I suggest you replace the mounting clips as they are bound to be broken. I didn't after doing some body repairs on mine, and the moulding came off on the motorway.
The each wheelarch moulding uses 5 of these:
They are part number 09-148-386 and cost £2 each. Mine should arrive Monday, and then I'll be able to fit the replacement moulding. That photo is of the only one out of a sample of 15 that is undamaged.
zirk
  • Epping Forest
« Reply #4 on: 16 January 2016, 14:27:14 »
Yea, lacquer, although windows spell checker seems to think otherwise.  ::)
Although after quiet a few liquors, you can pretty much not bother with the prep, spray it any colour and it will still look cool.  ;D
Zuffenhausen
  • Telford, Shrops.
« Reply #5 on: 16 January 2016, 22:04:29 »
 :y  :)
Zuffenhausen
  • Telford, Shrops.
« Reply #6 on: 25 January 2016, 23:22:00 »
Just need the two short pieces from the tailgate now, anybody got some?
