Ebay Elite. Project or Money Pit?
Started by JamesV6CDX, 17 January 2016, 14:30:04
So far have also ordered:
Timing belt kit
Thermostat
Aux belt
Aux idler pulley
Red coolant
New cat back exhaust and mounting kit
Unless anyone can convince me otherwise, given the good compression, I am thinking I will leave the heads in situ, especially as this car will have multi layer gaskets fitted?
I think I will also leave the water pump be. It's s gen GM item and feels absolutely fine, like new
The new cooler has arrived. Gm branded
No cover plate or o rings though. I guess no harm in using old plate.
It does seem to have a tiny ding as per top left of this picture. I don't suppose this would cause any issue?
To clarify I'm talking about along the vertical seam on the left of the picture
On a brighter note the mats have come up lovely in the washing machine, 3 hour 90 deg cycle, much to SWMBO's disgust
Here is one of them after a wash. It was as bad as the other
joff
Quote from: JamesV6CDX on 01 February 2016, 18:58:15
I still have the oil cooler you sold me last year, still in the box :y
Diamond Black Geezer
Quote from: TheBoy on 01 February 2016, 17:35:03
Quote from: Diamond Black Geezer on 01 February 2016, 13:26:11
Where'd you get the oil cooler from?? Do they have any more??  :o
Look after your coolant, the oil cooler will not fail ;)
Thanks  :y Probably worrying about nothing, then. I'm currently on a 50-50 mix, so fingers crossed! I'm thinking of the previous years of neglect from a certain un-named male parent of mine...  ;D
Any more thoughts on this before I fit it :y
Sorry I can't speak from personal experience on this, James, but it looks fine to me. Unless they've got another they are willing to swap it for just on the offchance. It's clearly had a little 'belt' but the insides are reasonably robust, aren't they? not quite as delicate as a cat or a radiator?  :-\
If you're not sure, either pressure test it or don't use it...
I don't have the means to pressure test it and the cost of having it done would be prohibitive
My gut feeling is that it's fine and only superficial, I was just after views of others
I guess I could cut the old one open just to see
I reckon you could drill a hole in one of those plastic plugs, fit a schraeder valve, pressurise it and drop it in a bucket of water. Would save a lot of wasted time if it is knackered. :y
Bigron
The dent doesn't look THAT bad, but what is the discolouration - corrosion?
Could the damage have caused plating separation, allowing degradation to take place, or am I talking through my a**e?!!
Ron.
Quote from: Kevin Wood on 02 February 2016, 14:20:57
What sort of pressure would you suggest?
Quote from: JamesV6CDX on 02 February 2016, 14:18:42
You could easily make a pressure tester from a pair of the pipes that connect to the cooler.
Crimp and solder one end up, and solder a tyre valve in the other. Pressurise with a footpump. Your Haynes manual probably gives some idea of how much pressure the oil system makes.
Yep, 2 or 3 BAR would be enough but I doubt you'd need that much to see a stream of bubbles if it's punctured.
