Author Topic: How 2 Identify camshafts?  (Read 2370 times)
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« on: 17 January 2016, 20:22:12 »
I have a friend looking to install 4 G intake camshafts to a 3.2 Liter engine for a Catera project. He has an assortment collected over the years. The shafts are not on heads. How can he identify the G cams? Is there some marking he should look for? He says He sees he shafts are not on heads. How can he identify the correct cams? Is there some marking he should look for? He says He sees gc15, gc18, gc20, a2, e5, three are stamped 3, and another stamped 4. If those markings aren't familiar, what about the cam lobe profile. Any help would be appreciated.
« Last Edit: 17 January 2016, 20:25:58 by elvin315 »
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: How 2 Identify camshafts?
« Reply #1 on: 17 January 2016, 20:35:44 »
The letter is very small and engraved on the cam.
Hoof'land storeman.
« Reply #2 on: 17 January 2016, 20:36:23 »
The markings are on the front of the camshafts, just behind the first bearing shell
You should NOT have 4 x G cams. That's a common misconception..... there is no benefit in using G cams on the exhaust side.
On a 3.2, its G cams for inlet, and J cams for exhaust...
On s 3.0, G cams for inlet, A cams for exhaust...
