Secondary battery installation
Started by Gaffers, 19 January 2016, 17:12:46
Quote from: Guffer on 20 January 2016, 13:31:45
Initial inspection of the wire guage suggests so Kevin.  But I wonder how much it would handle if I was powering a towed caravan  (heaven forbid)  as well as charging get the leisure battery  ::)
Pikey!
The thing is, as soon as the wire starts to get heavily loaded, the voltage at the "boot" end will drop, so any charge being absorbed by the leisure battery will drop off quickly. It might end up being self-regulating, although the run of cable needs to be appropriately fused, of course, so that would ultimately stop it ending too badly.
I ran a 40A rated thinwall cable into the boot for my amplifier. It now also runs a ham radio rig. It was easy enough to route the cable, so you might as well go that route, IMHO. The thicker the cable, the less voltage drop and the more effectively the leisure battery will charge.
Gaffers
Quote from: Kevin Wood on 20 January 2016, 13:38:36
Pikey!
Thats scared you didn't it?! :D
I wouldn't be converting the rear space of the miggy if I was going to get a Pikey van.  I don't want a tent because I am normally too tired after a fishing session to do much else.  It's amazing how much a zen sport like this takes its physical toll.
Quote from: Guffer on 20 January 2016, 14:49:47I don't want a tent because I am normally too tired after a fishing session to do much else.  It's amazing how much a zen sport like this takes its physical toll.
Excuses, excuses.. You'll be taking a dump in your wardrobe before you know what's happened.  ;)
Is there anything to say that a second, identical charging relay and loom couldn't be fitted, thereby retaining the tow bar supply and the boot supply :-\
Quote from: Harris K Telemacher on 20 January 2016, 16:37:52
No.
Quote from: Kevin Wood on 20 January 2016, 17:26:24
No.
There's your solution then Matt :y
I think I have another loom buried in the garage...
Gaffers
Quote from: Kevin Wood on 20 January 2016, 16:03:12
I actually have a portapotty for that  ;D
Gaffers
Quote from: Harris K Telemacher on 20 January 2016, 18:25:30
No.
steve6367
While I don't disagree that the thicker the cable the better in principle,  the GM installed feed does would and is adequate in my experience.
As its so quick you may like to connect it up and measure the voltage drop before you go to all the hassle of running another cable.
Steve
Auto Addict
Quote from: Kevin Wood on 20 January 2016, 13:43:26
I was always under the impression, the more strands of copper wire in the cable, the more efficient it became.
I like red cars
Quote from: Auto Addict on 21 January 2016, 08:48:53
It's the total cross sectional area of copper that's important (for DC, at least). Making that area up out of multiple strands instead of one solid strand (as is used in house wiring, for example) just makes the wire more flexible.
omega2018
you could always upgrade the main battery to a diesel spec 85a/h  so that's near 30% more than the standard 66a/h assuming you are not diesel already. they just about fit in.   then if you also carry one of the new generation small lithium jump starters in the boot you needn't worry about not being able to start in the morning.
not as good a solution as a separate leisure battery and charging circuit, agreed,  but much easier.
