Author Topic: Compressor storage ?  (Read 4208 times)
EMD
  • Noofhampton
    • 95t
« on: 21 January 2016, 08:40:13 »
Can an air compressor be situated outside open to the elements or is that a no no  :-\ I haven't got space in the shed but room next to it outside .
Omegatitis
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Compressor storage ?
« Reply #1 on: 21 January 2016, 08:51:01 »
I wouldn't leave it outside to the elements, covered with say a tarpaulin might be OK :-\
I like red cars
« Reply #2 on: 21 January 2016, 08:58:14 »
Can you not construct a little wooden lean to to house it in?
flyer 0712
« Reply #3 on: 21 January 2016, 09:07:40 »
construct a water proof wooden box covered with shed felt with a door to gain access to it if required..pass cable through hole in the wall from inside the box...best off also fitting a water drain into the air line inside your garage/workshop to catch the condensation that you will get in the air....always a good idea to fit this even if compressor is in the garage....I have done this and never had a problem...just make sure that you inspect the compressor on a regular basis to make sure all is well. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 21 January 2016, 09:15:01 »
Get one of those plastic garden containers.
EMD
  • Noofhampton
    • 95t
« Reply #5 on: 21 January 2016, 09:37:20 »
Thanks , a small lean to sounds just the job and thanks for the tip on draining
the excess water . Luckily i kept a store of the old wood from the demolished shed  :y
Omegatitis
« Reply #6 on: 21 January 2016, 11:40:59 »
That's exactly where I plan on situating mine (behind the 18x10' shed) when I get around to it.. if nothing else you'll still be able to hear yourself think in the shed when it kicks in! ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 21 January 2016, 12:08:26 »
Mine has lived outside against the wall for about ten years. I've nowhere else to keep it.
Keith ABS
  • Maldon Essex
« Reply #8 on: 21 January 2016, 19:48:31 »
  A regular pull/twist of the tank water drain will also be needed especially if sited outside. Once a month should suffice
Keith ABS
« Reply #9 on: 21 January 2016, 20:40:18 »
I try to drain mine at least fortnightly, and some nasty shite often comes out of it ;D
In fact I did it earlier today, because I'm a good boy :)
Not sure I'd leave mine out, as its the usual Chinese tat (mines Clarke, but same as Sealey/Aldi/Airtools/ACME), I'd give it 3 months outside....
EMD
  • Noofhampton
    • 95t
« Reply #10 on: 22 January 2016, 12:31:54 »
97dB would be quite an ear basher in close proximity so just as well its going outside where it will annoy the neighbours   ::)  If its too loud maybe put some insulation in the compressor housing . It shouldnt cut in and out very much at all though .
Omegatitis
« Reply #11 on: 22 January 2016, 12:40:05 »
Mine is in the garage at the moment - detached, concrete etc - and if I forget and leave it on I can hear it cycling at night when I'm in bed, about 15m from the garage..  :-X
Which usually prompts me to go outside and turn it off, at least! ;D Luckily none of the neighbours have been out and about while I'm doing that yet or they'd get a heck of a shock at the sight of me in my undercrackers.. ;D ;D
« Reply #12 on: 24 January 2016, 13:23:47 »
Some things cannot be unseen! :o :o
Pass the bleach please
  • Auckland
    • Mazda MPV
« Reply #13 on: 24 January 2016, 13:33:59 »
I would worry about the motor and electrics getting damp :-\
I had an electric chainsaw which I used to keep in a concrete sectional garage - it didn't get wet as such but after a period of damp weather I went to use it and it spewed a shower of sparks out of the motor and stopped :'(
That said - the compressor should have a TEFL (totally enclosed fan cooled) motor so maybe it is designed to cope with the damp :-\
EMD
  • Noofhampton
    • 95t
« Reply #14 on: 24 January 2016, 13:52:08 »
Ive not seen anything that states it shouldn't be stored outside in the description but hope the little outside shed will keep it in good order . Only other thing i was thinking was to try and get it installed under one of the benches in the shed once the omega spares have been moved to another destination  ::)
Omegatitis
