Pages: [1] 2 3  All   Go Down
Author Topic: 2.2 Petrol Stat Change  (Read 8860 times)
« on: 21 January 2016, 18:59:54 »
Picked up new stat, the rubber gasket is already on the stat housing.
Is it worth taking this off, then putting a tiny bit of grease around the rubber gasket, then re-seating?
Or just apply to the surface/stat housing on the engine block where it's mounting to?
Re: 2.2 Petrol Stat Change
« Reply #1 on: 21 January 2016, 19:03:57 »
If the seal is happily in place, simply fit it ;)
« Reply #2 on: 21 January 2016, 19:04:55 »
Ta  :y
A little job for the weekend  :)
T.m.f
    • 4wd
« Reply #3 on: 21 January 2016, 19:38:38 »
10 mins max to change ,any longer than that then you shouldnt be working on an engine lol  :y
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
flyer 0712
« Reply #4 on: 21 January 2016, 20:13:34 »
You still got time to do it tonight..its dark and cold....ideal job.. ;D ;D
« Reply #5 on: 21 January 2016, 20:28:58 »
Done it before  :y
Was one of my very first jobs that I did  :)
« Reply #6 on: 21 January 2016, 20:46:14 »
Done it before  :y
I remember :y.  Probably a good excuse to flush the coolant through as you have to partially drain anyway :)
« Reply #7 on: 21 January 2016, 21:02:00 »
Done it before  :y
That's why I bought a bottle of coolant too  :y although it's not long since it has a good change. Belt and water pump was changed last year.
« Reply #8 on: 25 January 2016, 09:35:00 »
Hummm something is still not right, only warmed up to ~80c on the gauge today really. Huge chunk of the first part of my commute is stop/start 50mph average down the M3. Bit more speed on M25, saw it rose very slightly.
Oddly, when I came off motorway for Heathrow (and came to a stop) it went to 85 quite quickly. But going around the Heathrow perimeter road, it would range from 80/85, tending to go to 85 when stopped.
Stop/start driving saw it around 82  :-\
Parked up at the office, it went past 85 up to 90. Then stat must have opened more and brought it back down to 80, then onto 85 again. Fan did not turn on, so must have been via the stat.
I do have a slight leak from the coolant pipe on the stat that runs to the throttle body, but then temp changes don't appear right.
Normally once on 85c it would stay there, no matter what.  :-\
« Last Edit: 25 January 2016, 09:39:32 by tunnie »
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #9 on: 25 January 2016, 10:12:52 »
What is the heater temperature like? On hot is it pumping out very hot or just warm?
I have a 2.6 that has hot air from the heater, but the actual temperature gauge barely gets to the first mark on the gauge. I am thinking that maybe the sender unit that isn't registering the correct temp to the gauge.
On an old VW Golf GTi MkIV that we had years ago, the sender unit also sent the temperature readings to the ecu regarding the air fuel mixture, so a dodgy sensor gave the wrong info resulting in incorrect fuelling. Don't know whether this aspect applies to an Omega....
« Reply #10 on: 25 January 2016, 10:18:56 »
Heat is good, perhaps not the cooking heat it's been before. But still very hot.
I'm thinking air pockets/trapped air, but then I might not get heat at-all  :-\
« Reply #11 on: 25 January 2016, 11:29:09 »
Heater set to Hi, fan to one bar, then expansion cap off and run it until the fans kick in twice, cap back on and give it a run, then report back :y
Don't forget, start this from cold and once done, again from cold, check the stat to rad hose as it warms up :y
« Reply #12 on: 25 January 2016, 11:33:18 »
Getting fan to kick in a? That's quite hard on the 2.2, only tend to hear that on a hot summers day  ;D
I did run it for a bit, burping the air out, but will admit, did not keep cap off the whole time. Put it back on when warming up.
« Reply #13 on: 25 January 2016, 11:35:08 »
That's where you've gone wrong, cap stays off until it's hot :y
« Reply #14 on: 25 January 2016, 11:56:30 »
I might do this before my drive home, get it hot with cap off, before setting off.
Might look like a bit of a n00b reving the car with bonnet up in the multi-story at work, but ahh well  ;D
Pages: [1] 2 3  All   Go Up
