Author Topic: stripped threads on sump plug!  (Read 3822 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« on: 21 January 2016, 22:13:26 »
Best solution to repair sump plug that will not tighten or undo to remove.
  • Auckland
    • Mazda MPV
Re: stripped threads on sump plug!
« Reply #1 on: 21 January 2016, 22:21:11 »
Which engine?
The answer is very different depending on whether your sump is steel or aluminium.
« Reply #2 on: 21 January 2016, 22:56:27 »
As Andy says, if a V6, then the pressed steel lower pan has a pressed in ally insert with the thread in it. It's a long time since I bought one, but a new one wasn't stupidly expensive so I just replaced the whole thing. You just need a tube of grey instant gasket to glue it on with.
« Reply #3 on: 21 January 2016, 23:30:37 »
Good excuse to check/clean the sump strainer :y
« Reply #4 on: 21 January 2016, 23:32:03 »
 :y :y :y never a bad idea  :)
alfie
  • Gwent
« Reply #5 on: 22 January 2016, 06:36:05 »
Hi'the car is a seat leon td ,my son bought it last week,not a trace of a oil leek under the car as he inspected it,the owner did a good job of hiding it.After the 300 miles return drive from Bridport North Devon it was evident that there was a problem,when I noticed oil  on the garage floor. I hope the sellers new Volks Passet has a even biggar problem with his new purchase,it,s just to much hassle to drive a 500+ mile trip to sort things out with him.
                                                         Alfie.
  • Auckland
    • Mazda MPV
« Reply #6 on: 22 January 2016, 07:48:33 »
                                                         Alfie.
I think that car will have a VW engine.
The sump is aluminium. A new sump is about £50 from GSF.
Not a difficult job but you need to check whether it has an oil level/quality sensor before you buy the sump.
« Reply #7 on: 22 January 2016, 08:16:35 »
Secondhand sump from ebay/scrappy?  :y
alfie
  • Gwent
« Reply #8 on: 22 January 2016, 15:00:30 »
Thanks for the replys,ordered new sump (without level sensor) £35,get it sorted by next week.
                                                         Thanks to all
                                                             Alfie,
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #9 on: 22 January 2016, 18:50:00 »
Why is it when someone asks about stripped sump plug threads[even in gen chat]that everyone instantly thinks Omega and asks which engine? :D ;D
« Reply #10 on: 22 January 2016, 18:57:19 »
Good question ::) ;D
  • Auckland
    • Mazda MPV
« Reply #11 on: 22 January 2016, 19:01:52 »
It says Mondeo on Alfie's profile............
I wasn't expecting a Seat though ;)
It just happens that I smashed the sump on SWMBO's Golf a few years ago so I have form when it comes to replacing the sump on that range of engines.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 22 January 2016, 21:04:47 »
That is quite common on all versions of that platform. The 'sportier' versions which sit lower are particularly prone to it. I've recovered loads of them with an oil trail leading from the speed hump 200metres away. Further than that in some cases, but they tended to have knackered engines. All of the early Octavia taxis on Sheppey have sumpguards as there are a lot of unmade roads, and a lot of expensive repairs as a result.
alfie
  • Gwent
« Reply #13 on: 22 January 2016, 21:25:09 »
I thought that I had made it clear that it was my sons car,sorry for any misunderstanding,but back to the Leon it is a lovely car,fast comfortable and cheap to run,I love it.
But I do not think it will pull my caravan!
                                                        Alfie
  • Auckland
    • Mazda MPV
« Reply #14 on: 22 January 2016, 22:15:12 »
                                                        Alfie
You did - but not in your original post. :)
Page created in 0.023 seconds with 20 queries.
