bugger
Started by Gaffers, 22 January 2016, 08:27:52
Gaffers
Quote from: biggriffin on 29 January 2016, 08:20:56
Quote from: Kevin Wood on 22 January 2016, 09:34:48
Darn! >:(
You need to get a towbar!
Think telepmaker offerd one :'(
Ironically, I have had one one in the boot waiting to be fitted since before the collision.
Fitting that as part of the repair process could well help with ensuring that the floor is relatively square ;)
Gaffers
This is dragging on longer than I expected.
The update from today is that the assessor finally came out and looked at the car.  Pointed out something I hadn't noticed in that the NSR quarter looks to have been pushed in a 2-3mm.  This also means the boot floor might be buckled.
Bugger.
Quote from: Guffer on 04 February 2016, 18:39:23
Bugger.
Be fine...
Are you around next week at all?
Just take the money & buy sumat else  ;) ;) You also have to consider that insurance compnies don't like to insure write offs
Gaffers
I may have to.  Not what I wanted to do tbh.
Right, who's selling an estate in decentish condition for not much wonga? ::)
Quote from: Andy B on 04 February 2016, 18:53:12
That's scaremongering pure and simple... Never had an issue insuring mine.
It can be fixed to usuable condition with minimal fuss...
Gaffers
Quote from: Harris K Telemacher on 04 February 2016, 21:34:41
even with a warped boot floor?  Not 100% sure I'd be happy with that tbh :-\
Gaffers
Seen a 2002 525 going cheap with what looks like a misfire ::)
henryd
Quote from: Guffer on 04 February 2016, 22:09:32
Nice Wagon IF its a cheap fix like a coil,but if its something simple why hasn't the owner fixed it to make more money ??? ::)
other rides
Gaffers
Quote from: henryd on 04 February 2016, 22:14:05
He thinks that an occasional misfire and an EML is a blown HG  ::)
Is it? That's the first thing 'my' body shop said when I first enquired about SWMBO's Astra and the possibilties of repairing it after it was clobbered up the harris .... and he'd have got the work if it was going back on the road. As soon as it was assessed & declared written off, the insurance company at the time said they were suspending its insurance as they couldn't continue to insure it. The boot floor is bent .... is it really worth it?
Quote from: Andy B on 04 February 2016, 22:15:43
Couldn't or wouldn't ??  When Chris's clit was written off her Insurers refused to insure it .. transpired this is simply because they have a policy NOT to insure cat c/d cars at all. I had a new (to us) door put on and a new plastic wing, both resprayed by a proper bodyshop for 1/2 the cost of the insurers repairers estimate, and 2/3 rds of the amount they gave her. Car is now happily on the road and insured through Adrian Flux .. cat C and never had a VIC check  - and now doesn't need one so thats around £100 saved .. :)
Quote from: Entwood on 04 February 2016, 22:28:55....
Couldn't or wouldn't ??   ....
No idea. We took them up on their (eventual) generous offer  ;) as in Matt's case, the car's 'chassis' was bent .... the rear near side door fouled on the wheel arch as you opened/closed it.
Quote from: Guffer on 04 February 2016, 22:05:41
Really need to see it, but the outer panel only contacts the inner panel around the lower edge, up the tailgate seal and along the window line... If the tail light is still securely attached then I doubt the floor is that badly done... The light cluster bolts to both inner and outer panel, so significant intrusion would break the cluster... Also don't forget that the tailgate is now a different shape, altering the perspective of the rear quarters...
If the chassis rails are bent then you might have a point, but i'd be surprised if the assessor bothered to look underneath... The tailgate is £370 in parts alone... Bumper shell the same, plus another £100 for the crash bar... So nearly £800 before paint and labour... He would have written it off on a blury instamatic picture faxed to him tbh...
I have the official Thatcham repair manual, and have hands on experience of repairing these... Would also suggest the the rear end would be further strengthened with the fitting of the tow bar...
I will try to find the pics from the rear quarter damage on my white one... Inner wing was practically unscathed as was boot floor.
