Author Topic: Heater matrix.  (Read 4481 times)
ted_one
Heater matrix.
« on: 22 January 2016, 13:46:39 »
Is the heater matrix a standard part throughout the Omega range,or are they different for the later cars with climate control? :-\
Re: Heater matrix.
« Reply #1 on: 22 January 2016, 13:52:17 »
Standard part...
Here do...
http://www.ebay.co.uk/itm/Nissens-72655-Heater-Matrix-OPEL-OMEGA-B-94-/291580051089?fits=Car+Make%3AVauxhall%7CModel%3AOmega&hash=item43e3867e91:g:2CIAAOSwsB9WD0ww :y
« Last Edit: 22 January 2016, 13:59:57 by Harris K Telemacher »
Re: Heater matrix.
« Reply #2 on: 22 January 2016, 14:07:03 »
Hmm, still not entirely convinced mine's not leaking. :-\
Re: Heater matrix.
« Reply #3 on: 22 January 2016, 14:13:41 »
They've 9 in stock :D
Re: Heater matrix.
« Reply #4 on: 22 January 2016, 14:18:39 »
That's the easy bit. ::)
Re: Heater matrix.
« Reply #5 on: 22 January 2016, 14:22:41 »
True, but it's an easy afternoons work ;)
ted_one
Re: Heater matrix.
« Reply #6 on: 22 January 2016, 20:12:51 »
Got a part number here.....91 543 274, would that be correct?
Re: Heater matrix.
« Reply #7 on: 22 January 2016, 20:36:05 »
A quick rummage produces nowt :-\
Don't let the price in the link put you off, Nissens are well reputed ;)
ted_one
Re: Heater matrix.
« Reply #8 on: 22 January 2016, 20:51:50 »
Thanks Al,
               I've just been offered a couple of these 'old stock' with those part numbers.Just thought I'd see if anyone might know wether they are suitable :-\
Re: Heater matrix.
« Reply #9 on: 22 January 2016, 21:32:33 »
Thanks Al,
If they're for the Omega then I am sure they'll fit, but searching the part number produces no results :-\
ted_one
Re: Heater matrix.
« Reply #10 on: 22 January 2016, 22:16:28 »
Thanks again Al,
                       I'll have a look at them asap :-\
Re: Heater matrix.
« Reply #11 on: 22 January 2016, 22:47:43 »
Thanks again Al,
The ones I linked to give the dimensions ;)
amba
  • Medway towns
    • German V6
Re: Heater matrix.
« Reply #12 on: 22 January 2016, 23:21:43 »
Just my own advise here as replaced Matrix on my old Elite.
Bought a Nissen brand from ECP and think it was sub £40. It fitted fine but didnt have the foam block for the end and when it was fitted didnt sit in the recess very tight .After further investigation it was clear that the foam was quite important as it in effect sealed the matrix in the heaters plastic cowl and stoped warm aie escaping and also cold air from outside just passing straight out into the footwell.
Might be completely off track but would of thought genuine GM matrix units would be a prefered choice and would come with all the correct bits..just my experience but Nissen didnt although packing with foam did fix the issues
Re: Heater matrix.
« Reply #13 on: 23 January 2016, 01:40:14 »
The foam is, or at least should be in the box for attaching prior to fitting (saves transit damage)... Mine certainly was, fitted 70K miles ago and no issues since ;)
Wouldn't have recommended it if I wasn't happy with it...
amba
  • Medway towns
    • German V6
Re: Heater matrix.
« Reply #14 on: 23 January 2016, 08:40:45 »
I must of been unlucky when I bought mine,but as I wasnt aware it needed the foam when I opened the box I didnt complained to ECP as needed it as existing removedand due to major coolant all foam/etc was soaking  :(
Matrix was fine though and fitted as explained so I agree parts are fine just be aware you need the foam  :y
