Author Topic: 3.2 backbox  (Read 6010 times)
Re: 3.2 backbox
« Reply #15 on: 25 January 2016, 22:11:26 »
I use ETS or Eternal for exhausts. Except the chavmobile's backbox, as it has one of those posy Irmscher ones on.
ETS on all of mine, past and present. Just slap some cheap tat trims on the bit you can see and job done.
For the 3.2 with twin exit, what trim did you use? 2x single pipe trims? Did they fit side by side?
You need to measure the gap between the outlet pipes and do the maths because the last two ETS exhausts I have had the pipes at a slight angle to each other. I'm contemplating cutting the pipes back on the one I have for the next project so the larger trims fit.
I've got two Halfords trims from the chav section (although not many stores have the right size) on the daily driver and two ebay ones on the other 3.2.
Which sizes did you get? I need to have a measure. :)
Re: 3.2 backbox
« Reply #16 on: 25 January 2016, 22:29:00 »
Might be as easy to buy a facelift back box from ETS... :-\
The genuine one you have is obviously from a mid/pre facelift... rear bumpers are different depths, hence the wrong length ;)
