Author Topic: Ignition coil full of oil ..:(  (Read 2660 times)
krabi_one
  • Norfolk -Suffolk UK
  • Sound of V6 - I love it - but now 2.2 :)
    • Omega 2.2 CD 2001
« on: 24 January 2016, 18:35:21 »
Hi Guys,
I got small problem .
I started on cleaning and servicing the 2.2 omega and when to came to the rocker gasket...
I pull the ignition coil - the spark plugs were full right up to the rocker cover with old oil, a little bit cocked .
so I started sucking that oil and trying to clean what i can but, its still some sh..e on the bottom.
i cleaned everything as much as i thought be ok and put new gasket , cleaning throttle, new thermostat ,new filters etc.
and started -- bang 30000 fault codes came up. and big misfire.
took the cil back again and put some electric cleaner - and a lot better but still 2 codes p0354 and p0302
and works like a tractor.
I sprayed quite a lot of electric connector cleaner were the spark plugs are , and I think no.2 leaked a bit inside
Now my question how to clean everything right up to make sure when I take spark plugs out no shite go down the hole ?
some of the pic. first one with still some oil but cleaned like 0.5 litre out already.
« Last Edit: 24 January 2016, 18:37:54 by krabi_one »
Re: Ignition coil full of oil ..:(
« Reply #1 on: 24 January 2016, 18:44:28 »
You did change the plugs I assume?
krabi_one
    • Omega 2.2 CD 2001
« Reply #2 on: 24 January 2016, 18:48:24 »
No I didn't, I put all back - didn't took the spark plugs out  yet ( just cleaned them quite good but right on the bottom is still some old oil and the worst cocked a bit ) - I wanted to change the Oil first, and then figure out how to clean them properly before removal.
« Reply #3 on: 24 January 2016, 18:59:04 »
Small amount of oil dripping into the bores is Ok
« Reply #4 on: 24 January 2016, 20:11:02 »
There's a guide for camcover gasket and breathers... the 2.2 is just as susceptible to breather blockage issues as the v6 :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #5 on: 24 January 2016, 22:40:43 »
Compressor air line and a rag around it to contain the oil blown out should do the job if you are concerned at the oil remaining being contaminated with grit. :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 24 January 2016, 22:50:01 »
You'll get almost all of the oil out of the plug wells using a small syringe. The small amount left will drip into the combustion chamber when you remove the plug, but it won't matter. Wipe the well with a twisted rag before you fit the new plug and you're done. Quick,easy, tidy and cheap - what more could you ask for?
A small syringe is a handy thing to have when working with car fluids; you can remove or replace small quantities easily and tidily.
krabi_one
    • Omega 2.2 CD 2001
« Reply #7 on: 26 January 2016, 19:37:09 »
Thank you guys,
I have done - air and catch all of the stuff with rag,
then a more and more cleaning with screwdriver and rug.
on the end when it was not bad, after removal the spark plug I used hover (with extension - a bit of grade water hose)
then when everything was ready i put new spark plugs - Hurray :) no fault codes and car totally different :)
« Reply #8 on: 26 January 2016, 20:00:04 »
Thank you guys,
Good job, now do the breathers and change the camcover gasket, otherwise it will all be in vain ;)
krabi_one
    • Omega 2.2 CD 2001
« Reply #9 on: 26 January 2016, 20:21:07 »
All done :) cleaned the breathers and throttle and the gasket :) additionally replaced the expansion tank because was showing low coolant but was not, new coolant, new oil, new filters all of them , new passenger sun visor ,and changed the OFF button on the climate control, new mirror , new catch for the fuel cap and some more :) ... Omega is a lot more happy now :)
« Reply #10 on: 26 January 2016, 20:28:29 »
