Author Topic: Omega 2.2 petrol Z22XE 2003 post cat gasket number needed please  (Read 1664 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
As in the tittle says, a post cat gasket part number needed and the part number or the size of bolts for that exhaust flange please.
Thanks
Re: Omega 2.2 petrol Z22XE 2003 post cat gasket number needed please
« Reply #1 on: 30 January 2016, 18:26:44 »
There are no gaskets post cat.
« Reply #2 on: 30 January 2016, 18:27:08 »
2 9157096  8 54 928 GASKET, FRONT EXHAUST PIPE TO MANIFOLD
Is manifold to cat section
Andy A
  • Bristol UK
« Reply #3 on: 30 January 2016, 19:53:06 »
Where the exhaust front, post cat connects to the centre section of the exhaust on the flange there is no gasket in there. Are they just a tapered fit then and do I need to re-tighten  bolts to seal or should I put some exhaust sealant past in there and then re-tighten the bolts?
I had a new clutch put in a while back and they couldn't of tightened the two bolts up tight enough.
Thanks
« Reply #4 on: 30 January 2016, 20:07:31 »
I believe its a taper. Should be fine without paste, but if not, a thin smear of paste before fitting to taper.
Key is to clean it up properly first.
Andy A
  • Bristol UK
« Reply #5 on: 30 January 2016, 20:40:48 »
Will do and thanks for the info and advice.  :y :y
Andy
