Author Topic: Replacement aerial(antenna) rod  (Read 3154 times)
benko5009
  • Budapest
    • Omega automatic 3.2 V6
« on: 30 January 2016, 18:12:37 »
My aerial rod(a very short one) was stolen.
Can somebody suggest a replacement one ? (not necessarily the original)
The car:
Omega Sedan 3,2 V6 Automatic
The audio:
BOSE system with Philips CCRT 2008 Head unit AM FM GSM
Thank you,
Balazs
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Replacement aerial(antenna) rod
« Reply #1 on: 30 January 2016, 20:55:08 »
If its a Saloon, the whip is just a 1/4 wave at GSM so should be easy enough to source without buying an Opel one.
benko5009
  • Budapest
« Reply #2 on: 30 January 2016, 21:23:02 »
Yes, it's a Saloon one.
zirk
  • Epping Forest
« Reply #3 on: 30 January 2016, 21:27:31 »
So as above just 1/4 whip for GSM whith the correct screw in thread.
benko5009
  • Budapest
« Reply #4 on: 30 January 2016, 22:51:39 »
Thank you Zirk !
BTW.: will it be OK also for FM ?
« Reply #5 on: 31 January 2016, 00:59:00 »
Thank you Zirk !
FM/AM is in rear screen ;)
benko5009
  • Budapest
« Reply #6 on: 31 January 2016, 12:13:51 »
Thank you Zirk !
Thank you Harris !
It's totally new for me.
So, in my car the CCRT 2008 receives the radio(AM/FM) signals from rear screen heater, and the outside aerial(whip) works only for phone(GSM) ?
Best regards,
Balazs
« Reply #7 on: 31 January 2016, 12:19:35 »
