Author Topic: Oil warning light wont go out.....  (Read 6038 times)
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« on: 31 January 2016, 15:01:57 »
So whats folks opinions, Im reckoning oil pump...
Oil warning lamp is lit and wont go out, plus theres a very distinct rattle coming from top of engine, possibly oil starvation...?
Would it be the suspect of a new pump required....?
Anybody got any links as to where to obtain 1 that is available for me to collect, local to Wigan.... :y
D.I.L.L.I.G.A.F...
  • Auckland
    • Mazda MPV
Re: Oil warning light wont go out.....
« Reply #1 on: 31 January 2016, 15:23:08 »
Unlikely to be the pump - very likely that the pick up strainer is blocked with gunge.
To change the pump involves undoing the bolt in the end of the crankshaft - people struggle to shift it even with a 3 foot scaffold tube.
Start off by dropping the oil pan and cleaning out the sump and pick up strainer. If that doesn't fix it - or if the noise continues even after the oil light goes out then the big ends will need re-shelling :(
minifreek
  • Wigan
« Reply #2 on: 31 January 2016, 16:08:58 »
No noise from the big ends though....?
OK, I'll start by dropping the oil and take a look at the strainer... hope its as easy as that, didn't really want to shell out for a new pump. Would be cheaper to get another engine....
D.I.L.L.I.G.A.F...
tidla
  • solihull
« Reply #3 on: 31 January 2016, 16:35:21 »
Is the oil pressure switch easy to get at? worth disconnecting the plug and earthing to check operation?
minifreek
  • Wigan
« Reply #4 on: 31 January 2016, 16:53:35 »
Was also thinking that too TIDLA, but the engine is making a hell of a racket at the top-end...
I'll do what ANDY H suggested and drop the sump and clean the strainer... hopefully it'll only be that....
thanks for the suggestion though :y
D.I.L.L.I.G.A.F...
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #5 on: 31 January 2016, 17:02:07 »
Oil pressure switch is just to the left of the crank pulley - as you look at the front of the engine ;)
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
    • Carlton, Senator, Omega Spares.
« Reply #6 on: 31 January 2016, 17:14:24 »
As said unlikely to be switch if accompanied with some top end noise.
Has it symptom started after an oil change?
Have you used an engine flush?
Best move is don't run it! sump off check pick-up, clean if need, change filter, new oil then crank over without the engine starting immobilise by whatever means (pull the injector relay). See if the oil light goes out.
minifreek
  • Wigan
« Reply #7 on: 31 January 2016, 17:14:33 »
Thanks, possibly worth replaceing too....
D.I.L.L.I.G.A.F...
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 31 January 2016, 17:20:51 »
A new one is only £4.
But the noise suggests a lack of flow/pressure, which isn't difficult to check.
Cleaning the pickup in the sump is the place to start.
Hopefully your noise is just oil starved lifters, and not knackered cam bearings.
minifreek
  • Wigan
« Reply #9 on: 31 January 2016, 17:21:49 »
Its kinda been an intermittent type thing...
Every now and then I get the oil light come on, stay for a couple seconds then go out. Only happened when at idle, give it a blip of revs and it goes away...
The engine is due an oil and filter change, and TBH a bloody good service. Iv just been looking at pricing up filters for the AR25 to change the AT fluid and PS fluid too... Need this car to last a while longer, well at least another 12months... MoT not due until March so will be servicing it before it goes for its test. Also exhaust has a blow, somewhere from the front - Im suspecting manifold... might be time to update to the 2.6/3.2 headers... Not touched this car for a while as Iv just been too busy dealing with bereavments in the family, so car servicing has been on a backburner for a while... plus the weather hasn't helped either...
D.I.L.L.I.G.A.F...
minifreek
  • Wigan
« Reply #10 on: 31 January 2016, 17:23:44 »
Need to take the camcovers off anyway as theres an oil leak from the NS camcover... might as well do a full service whilst Iv got the bonnet up... No need to do the cambelt though, that was only done about 6-8 months ago...
D.I.L.L.I.G.A.F...
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
« Reply #11 on: 31 January 2016, 17:25:06 »
Ok, out of interest how many miles has the oil done and what oil in it at the moment.
minifreek
  • Wigan
« Reply #12 on: 31 January 2016, 17:27:56 »
Honestly, I really couldn't say but Im suspecting it hasn't been changed for about 20K, I only use Vx semi synthetic...
D.I.L.L.I.G.A.F...
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
« Reply #13 on: 31 January 2016, 17:54:59 »
So the oil looks like it's had a good bashing.
If it was mine I would be
Connect an oil pressure tester then crank over without the engine starting, see what results I get.
Whichever root is taken you need to minimise risk of engine damage.
  • Auckland
    • Mazda MPV
« Reply #14 on: 31 January 2016, 18:30:32 »
I would definitely drop the oil pan and give it a good clean in that case.
Simply changing the oil can be counter productive because the fresh oil tends to flush lumps of crap into the sump. If the strainer is already bunged up it is the final straw.
