Pages: [1] 2 3  All   Go Down
Author Topic: door mirrors  (Read 9895 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
door mirrors
« on: 01 February 2016, 10:02:44 »
theres a crack appeared overnight on my door mirror (suspect neighbours son cutting across drive with a bike) I have a pair of wing mirrors , but on an 02 plate elite are they more compact than other versions, & will they fit anyway  :-\
Diamond Black Geezer
    • & a silly coupe coming...
Re: door mirrors
« Reply #1 on: 01 February 2016, 10:09:32 »
Any Omega door mirror will bolt on to any other Omega  :y (assuming it's the correct side  ;) )
As borne out by my spares car (PFL) being fitted with FL door mirrors  :)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: door mirrors
« Reply #2 on: 01 February 2016, 10:34:53 »
Is it the mirror or the glass thats cracked,I replaced my broken glass with a stick on replacement.
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: door mirrors
« Reply #3 on: 01 February 2016, 10:58:25 »
If it's just the glass that's cracked, then try...... http://www.ebay.co.uk/itm/Right-Driver-Wide-Angle-Wing-mirror-glass-Vauxhall-Omega-00-03-heat-/290944465788?hash=item43bda43b7c. The nearside one is also listed from the same seller. £13 delivered. 5 mins to fit.
I replaced mine with one from this seller. Simply a case of gently unclipping the damaged one, unclipping the spade connector, refitting the spade connector to the new part and then gently clicking it into place.
Mine was a very good replacement. It fitted well, and adjusts & heats just like the original.  :y
raywilb
    • Citroen C4 Cactus
Re: door mirrors
« Reply #4 on: 01 February 2016, 11:59:06 »
thought about those stick on,s . but have noticed since post a crack on the back.
raywilb
    • Citroen C4 Cactus
Re: door mirrors
« Reply #5 on: 01 February 2016, 12:07:43 »
already have some, complete set of mirrors . just need to change colour from silver to black.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: door mirrors
« Reply #6 on: 01 February 2016, 12:20:37 »
Silver to black probably better than the other way around, but black does come in a range of colours. :y
Re: door mirrors
« Reply #7 on: 01 February 2016, 12:31:59 »
I understand that Elite mirrors are electrically different from others  :-\
Re: door mirrors
« Reply #8 on: 01 February 2016, 12:40:29 »
The Elites mirrors, I believe alter along with the electric seats, not sure if this means there's extra wiring in the mirror or not. However, this magic re-adjusting mirror will only be apparent if there's more than one driver programmed into the seat's memory.
... but as for the question 'will they fit' then any Omega mirror will 'fit' yes. And of course the simplest solution is for the OP take out just the glass from his spare mirrors, and use them; thus negating any potential wiring issues.  :)
Re: door mirrors
« Reply #9 on: 01 February 2016, 13:24:31 »
Re: door mirrors
« Reply #10 on: 01 February 2016, 17:58:52 »
Correct
Re: door mirrors
« Reply #11 on: 01 February 2016, 18:01:50 »
Correct
And perfectly interchangeable  :y
Mine has a CD drivers mirror... fitting non Elite mirrors will cost you the memory on said mirror, and fitting Elite mirrors to any other model doesn't affect the way it works :y
Re: door mirrors
« Reply #12 on: 01 February 2016, 18:03:26 »
Correct
Correct.
Although any elite owner wouldn't tolerate non elite mirrors. Stupidly useful, particularly on the FL ones which lack the vertical view of PFL
Re: door mirrors
« Reply #13 on: 01 February 2016, 18:22:21 »
Although any elite owner wouldn't tolerate non elite mirrors. ....
 :y :y
raywilb
    • Citroen C4 Cactus
Re: door mirrors
« Reply #14 on: 01 February 2016, 22:52:23 »
I did discover that there is a bolt plus 2 screws behind the door card. I managed all but one screw by  removing 2 door card screws. I could just prise it away enough to get at them. the one that remains I shall make something that will get at it. do not fancy removing door card.  :y
Pages: [1] 2 3  All   Go Up
