Author Topic: Fault code 0500 and multiple misfire  (Read 2290 times)
KeithmG
  • West Cornwall
« on: 01 February 2016, 17:31:43 »
My 2002 2.6 V6 has developed a misfire at low revs and ECU light illuminates.Local garage has identified two problems i.e output speed sensor and coil pack for cylinder 2. They have quoted over £200 for the output sensor and its touch and go with the price of the coil pack plus labour if the car is worth repairing or be condemned to the scrapyard. Any assistance in saving the car would be appreciated.
Re: Fault code 0500 and multiple misfire
« Reply #1 on: 01 February 2016, 18:00:37 »
Crank sensor is about £50+VAT from dealer, on trade. Coil pack is about £80 for a Bosch part.
Both should be fitted in under an hour.
KeithmG
  • West Cornwall
« Reply #2 on: 01 February 2016, 19:48:52 »
Thanks for the quick reply. I think the garage have identified the speed sensor as the transmission output shaft speed sensor which may account for the confusion on price. Do you think they are barking up the wrong tree?
« Reply #3 on: 01 February 2016, 20:17:36 »
KeithmG
  • West Cornwall
« Reply #4 on: 01 February 2016, 20:51:24 »
Pedal trick gives codes 0500
K_V6
  • Spain
    • Omega y22dth/Vectra let
« Reply #5 on: 01 February 2016, 21:40:15 »
Check the spark plugs. Sometimes gives ecu gives this fail for bad condition of this
From Spain. Sorry for my English
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #6 on: 01 February 2016, 22:12:54 »
No 0300's?  :-\
I thought P0500 was powertrain related.  :-\  (would explain the sensor but not the misfire)  :-\
« Last Edit: 01 February 2016, 22:23:02 by YZ250 »
